H/C C5 LS1 346c.i. dyno 430whp / 400wtq
2000 Corvette C5, stock LS1 bottom end, 6 speed manual, 3.42 gears.
Mods are:
-Blackwing intake
-GM 85mm MAF
-Unported LS6 intake
-Lucas 42.5lb fuel injectors
-Walbro 225lph fuel pump
-NGK TR55 plugs
-MSD 8.5 wires
-PRC stage 2.5 CNC'd 5.3L heads w/62cc chambers
-Comp cams rocker arm trunions
-TSP 7.40" pushrods
-GM LS7 lifters
-TSP Torquer V3 cam 231/234 .643/.598 112 LSA
-Flycut pistons
-Ported LS6 oil pump
-LS2 timing chain
-TSP 1 3/4" longtube headers
-3" catless X-pipe
-Z06 Titanium exhaust
-LS7 clutch and flywheel
-Tuned by Fast Motorsports
Mods are:
-Blackwing intake
-GM 85mm MAF
-NGK TR55 plugs
-MSD 8.5 wires
-TSP 7.40" pushrods
-GM LS7 lifters
-Flycut pistons
-LS2 timing chain
-3" catless X-pipe
It was not detonation. Simply a little interference in the pickup on the dyno. It was cutting out that day and this was the only run with a solid line where the other couple of runs had breaks where signal was lost
SWEET98SS, drivability is remarkably smooth, even in 1st gear off of idle. I believe the car is tuned extremely well and it had a good amount of tuning time to get it just right, I think. Forum member 'chevyls10' is the gentleman who tuned the car so maybe he can chime in to verify that. Not concidering the sound and lope, but just from the drivability alone, I think most couldn't even tell it wasn't stock.
And another thing which is a bonus, the car gets about 33mpg highway, 22-23mpg average. The fuel mileage if I stay out of the throttle is actually slightly better then it was stock.
