Only 360rwhp?? is it true
Old 01-20-2012, 11:41 PM
Justinktm's Avatar
Default Only 360rwhp?? is it true
ok i have a 00 ss automatic with
Longtubes
4:10 Gears
tv2 cam 232/234 .595/.598
3600 stall
slp lid
also the second gear was slipping at the time but it went all the way till about 5500 then slipped so could that be why i only dynoed at 360?
i dont understand why it was only 360
Old 01-20-2012, 11:54 PM
Blk98Vert's Avatar
Need more info. Stock LS1 intake? Exhaust setup? And why are you dynoing in 2nd? 3rd gear is 1:1 on these cars
Old 01-20-2012, 11:59 PM
Justinktm's Avatar
stock ls1 intake had 2 1/2 trueduals dumped before axle dynomax bullets and thats what they did it in
Old 01-21-2012, 10:38 AM
w3s1c0a5t's Avatar
The intake is chocking you a lot. Just an ls6 would probably add 20rwhp.
Also to compare number with most on here you need to run the dyno in third to have it 1:1.
Old 01-21-2012, 11:20 AM
karpetcm's Avatar
If your an auto you should'nt be in 2nd. Also i have to agree with above dump the LS1 intake and what type of dyno machine were you using?. If its a mustang dyno you will definitly get lower numbers then the norm with the dynojets and dynapack machines but you also need to address the slipping issue as well.
Old 01-21-2012, 05:03 PM
redtan's Avatar
You answered your question right there, taking it to 5500 is nowhere near where that cam will make peak power. You also have a stall and gears, so that will eat a lot of power on the dyno.
Also, keep it in 3rd otherwise you can't really compare numbers.
Old 01-22-2012, 02:46 AM
Justinktm's Avatar
alright thanks everybody i needed something for closure becuase i went back and they said thats how much i should make i wont be any more and they said they can try and fix the tune for another 500$ i was like ah ill just leave it alone then lol
Old 01-22-2012, 04:40 AM
lemons12's Avatar
Dyno numbers mean nothing, especially in an auto.
Old 01-22-2012, 05:03 AM
caviness's Avatar
You need a new tuner I'd take it somewhere else for sure,nobody dynos in 2nd gear unless you got a glide haha.
Old 01-22-2012, 05:06 AM
caviness's Avatar
If you paid them to tune it the first time I'd take it back and tell them to finish the tune or give my money back
Old 01-22-2012, 05:28 AM
Intimidator02SS's Avatar
How much power are you expecting?
Sounds like your car needs some help before you start pointing the finger at the tuner. Get your transmission fixed which will obviously give you more power to the wheels, and have your tuner check your stuff again.
Did you purposely take your car to the dyno with a slipping transmission or did you find out it was slipping during the dyno run?
Old 01-22-2012, 06:17 AM
Captain Double Post
BOBS99SS's Avatar
imo between having the ls1 intake and an auto that is slipping,and only going to 5500, that isnt bad at all, honest that intake is a choke hold , also i dont know if i missed it but what kind of dyno was it, 360 to the rear with those issues on a mustang are great numbers
Old 01-22-2012, 11:23 AM
Justinktm's Avatar
no it wasnt slipping untill the dyno run then the tranny went out and now i have a built tranny but they wanna charge me another 500$ to retune and fix my idle becuase it wont idle anywhere i have to stall it up
Old 01-22-2012, 12:59 PM
WSsick's Avatar
They would charge you full price for another tune?! **** that place. Most people around here are $50 or less for a retune unless something very drastic changes. Sounds like the are a bit shady, maybe a bit stupid as well if they are dynoing in 2nd.
FWIW, my buddy made 351rwhp with an SS4000, torquer 2, 1 7/8" headers, LS6 intake, 98mm lid and a tune. The dyno is known to be a low reader...which was proven when he would destroy cars make 70+rwhp more than him. Like lemons said, dyno numbers dno't mean **** on an auto.
Old 01-22-2012, 01:04 PM
jsteele90's Avatar
wow, my tuner does free retunes. but dont expect high numbers for a stalled auto, they are not dyno queens like m6 cars
Old 01-22-2012, 01:16 PM
Take a loss with your investment in this "business". If you paid them once and they can't even get your idle correct, what makes you think another $500 will make things any better? Run away and don't look back.
Old 01-22-2012, 01:46 PM
Justinktm's Avatar
i know theyre supposed to be really good in Oklahoma but id dreather have a newby hp tuner give it a go then them lol im going to try one more place if that dont work then i guess ill have to learn myself
Old 01-22-2012, 03:09 PM
Omega Doom's Avatar
my car dynoed 414rwhp with a Yank 4200 stall so........
Old 01-23-2012, 12:45 AM
itsslow98's Avatar
cool story bro.
Old 01-23-2012, 08:50 AM
thunderstruck507's Avatar
Where did you go? Sounds like a crappy shop.
An honestly, if you made that much power at 5500rpm with a dying trans and ls1 intake through a stalled auto you should be fairly pleased.
Quick Reply: Only 360rwhp?? is it true
