CMS C6 z06 E85 Results
Old 01-10-2012, 01:49 PM
jimbob's Avatar
Originally Posted by Ryne @ CMS
i normally get about 24ish on the freeway in sixth , i getting about 17-18 right now... i might be able to get that number higher but i havent had much time to mess with it
Nice gain with the switch..
I'm trying 45 degrees timing, instead of 32, at part throttle (on E-85), hopefully, I'll get a milleage bump. What are your thoughts on this much timing?
Old 01-10-2012, 05:25 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i dont think it will help that much.... 45 degrees at what rpm? i have decent size cam if i throw that much timing low in the rpm with buck pretty good... i cruising at 40 degrees above 1800 right now
Old 01-10-2012, 08:04 PM
jimbob's Avatar
Cruise rpm, similar to your 1800 rpm, actually more like 2200 for 60mph now. Sounds doable..
Old 01-13-2012, 01:42 PM
Detoxx03's Avatar
That's killer.
Quick Reply: CMS C6 z06 E85 Results
