Pleased With My H/C Combo!
Old 01-09-2012, 05:04 PM
strokerrace's Avatar
Thumbs up Pleased With My H/C Combo!
2000 Trans Am LS1 90k
-228R
-PRC Stg 2.5 5.3 milled to 59cc chambers
-PRC Dual Spring Kit
-LS6 Ported Oil Pump
-BRP pickup tube girdle
-COMP Magnum 7.4 pushrods
-GM mls head gaskets
-GM head bolts
-LS7 lifters
-LS2 lifter trays
-New Waterpump
-New Alternator
-Repacked all pulleys
-New Belts
-160 Thermostat
-All new gaskets everywhere
-ARP Flywheel Bolts
-LS6 intake
-Ported Tb
-LS6 Valley Cover
-LS6 Steam Tubes
-All new Sensors on motor
-Greentop 42# injectors w new orings
-Tr55s
-Taylor 8.5s
-Pacesetter 1 3/4 w gm gaskets
-Moser 9" 3.50 gears
-Texas Drivetrain T56 Stage 2 Trans
-Diamond Stage 2 Clutch Kit
etc...
Heres the Numbers!
RWHP: 443.93
RWTQ: 409.36
Graph:
Old 01-09-2012, 05:20 PM
navyblueSS's Avatar
Nice numbers!
Old 01-09-2012, 05:22 PM
msydow's Avatar
pretty flat torque curve there. numbers dont mean too much. whats the butt dyno say?
Old 01-09-2012, 05:25 PM
john563's Avatar
small cam and 9 inch to boot..I have these same heads in an A4..I been very happy with mine
Old 01-09-2012, 07:11 PM
Well coming from a stock internal full bolt on car it definitely has some punch. Your right though, the torque doesnt hit as hard as I expected but its smooth power all the way through. I was also on 19" C6 wheels and was using my hooker catback if anybody cares to know..
Old 01-09-2012, 07:30 PM
JRENIGAR's Avatar
Same dyno I had mine tuned on to make #'s in sig. Nice place. Lets get together and see how they do sometime...
Old 01-10-2012, 02:07 PM
Johnnystock's Avatar
Sounds like a bit generous dyno for LS6 intake, 9inch, Pacesetter(ORY ??). Not hating, just saying
..anyway, looks like a very nice street setup, congrats!!
Old 01-10-2012, 02:32 PM
JRENIGAR's Avatar
Well, for reference they told me a bolt on ls1 with an auto usually makes 310-320 on their dyno, so???
Old 01-10-2012, 03:03 PM
Either its a really strong runner for what it is or a bit generous dyno. Not impossible by any case, thats not what I think BTW. For reference, I make 404rwhp and trap 117
Old 01-10-2012, 03:53 PM
JRENIGAR-
Cant see your sig info on my phone but whats your setup? Im pretty pleased with the tune so far, just gotta button up some other things since I made the swap and then see how it handles abuse.
Old 01-10-2012, 04:00 PM
Johnnystock, yes it may seem a little high but this motor still has the factory cross hatchings on the cylinder walls and has no signs of anything wrong with it/abnormal wear so far. Texas Speed said to expect anywhere from 420-430 at the least with this combo and it did just that and a little more! It definitely is a strong runner and it actually pulled close to those peak numbers on 3-4 dyno runs. It was a Dynojet so you know how those usually dyno higher...
Old 01-10-2012, 04:54 PM
JRENIGAR's Avatar
Originally Posted by strokerrace
JRENIGAR-
Stock engine,a4 trans, and 10 bolt 3.23 gear all with 190k on it, hooker lt's, tsp oryp, hooker catback, ls6 intake, ported stock tb, intercooled vortech v9-g trim with 8.5-9lbs@ 6000 rpm where it shifts @. Made 450/438 earlier this summer @ Dyno Speed. My car is close to 3900# with me in it because of extra **** like subwoofer box and 2 12in memphis subs and a big memphis amp. I also have heavy *** UMI weld in subframes and rear boxed control arms with poly bushings. 17in staggered ZR1's with 315 sumitomos that are heavier than the 16 in stockers. Glove box and console full of crap too. It ran 12.08 @ 117mph with 1.95 60ft @ Motorsports park last october. That same night there were a couple of 6 speed ls2 vettes with full exhaust and intakes running 12.5's @ 117-118mph with 60ft's almost identical to mine. If I can, I will try to post the dyno graph later this week, maybe...
Old 01-10-2012, 04:56 PM
JRENIGAR's Avatar
What was the race weight, 60ft, and da?
Old 01-10-2012, 06:18 PM
Wow. Have you had any issues with the tune? And hows driveability? Just curious... Feel free to PM me if you want to discuss in private..
Old 01-10-2012, 07:12 PM
JRENIGAR's Avatar
It drives perfect and still gets the same 21mpg it got when it was bone stock. It does, however, have some sort of hiccup when idling. It sometimes studders a lil bit almost like a 224r cam or something till I tap the gas or it just quits on its own after about 10 sec or so. I ask about getting it SD tuned and they kinda shyed me away from that saying it wasnt necessary at my power level and the stock maf would be fine, although, I have heard it will make a pound or two more boost without it. I have HP Tuners but wouldnt know how to do it unless someone told me and I dont wanna pay to have it tuned again. Its barely loud enough to hear in or outside the car at about 700-800 rpm's it has a slight whistle almost like the prochargers do. Im probably just gonna get a meth kit and see if that helps enough to stay away from no2 and just drive it. Josh says meth should get about 50-75rwhp more and if so that will just have to do. I dont beat on it everyday but I do have fun with it from time to time. It was tuned to be safe at 11.3-11.5 afr and about 12 deg timing wot. The iat's usually run about 11-15 deg above ambient. Usually a run from 50-120 or so makes it rise from say about 70 deg to 110-115deg just to give others an idea of how efficient or not the system is. If I ever get another engine I would like ls6 heads and cam, if that netted another 30-50 rwhp Id be thrilled. Im really not sure if the iron 6.0 or another ls1 would be better because of the 70 or so lbs this kit weighs. I dont want a really nose heavy dd car so aluminum might be my only option...
Old 01-11-2012, 08:59 PM
Ws6Dnero's Avatar
Hey man what color is your trans am? do you be out on summer?
Old 01-11-2012, 09:00 PM
Ws6Dnero's Avatar
oh an @Jrenigar would you happen to know a guy name mario that works at oreilly??
Old 01-11-2012, 10:32 PM
Silver with silver c6 wheels. Yea I drive on summer almost everyday ha
Old 01-11-2012, 10:34 PM
Glad to hear your tunes good as well. Looks like a nice DD from the results in your thread. Come on over to memphis sometime and lets go to the track. I havnt even been yet with the TA but plan on it when it opens back up this season.
Old 01-12-2012, 01:46 PM
2.2 60ft LOL 3.42 gear, race weight is 3650, ds, not sure 485 above see level??
Quick Reply: Pleased With My H/C Combo!
