C5 Z06 Pat G/EPS 226/230 cam only, makes 450/434??????????
Old 02-01-2012, 08:29 AM
FRiCK's Avatar
Default C5 Z06 Pat G/EPS 226/230 cam only, makes 450/434??????????
Been going to this shop for years. The dyno is always accurate. Pat G spec'd a cam for my buddies bolt on C5Z and we just got it tuned last night. Final numbers were 450/434 with 24* total and 12.4-5 across. Car is stock besides some old school breathless perf. Vortech rammer intake and Bellenger tri Y headers and no cats. Cam is a eps/LXL 226/230 on a 111 I believe.
STOCK 243's!! Car has 50k miles on it...
450/434?! C'mon.....
Pre cam his car did 389/380....
My CTS-V did 419/396 with the same cam on a 113+2
My current Z06 did 389/381 with long tubes, X, vararam and a tune. Identical to what his did.
I'm so lost right now! I compared all correction factors and they're all .010 within each other. This is a dyno dynamics dyno as well.
Anyone have any thoughts??
Old 02-01-2012, 09:23 AM
LSX Mechanic
Damian's Avatar
A definite dyno error. A stock bottom 346ci engine with stock unported heads will not make 434tq. Especially through a Corvette drivetrain.
Old 02-01-2012, 10:02 AM
redtan's Avatar
I think it's right on par, dunno why you think those are low numbers. On a non-corvette drivetrain, that's probably more like 430ish at the rear wheels. That's a good number for a medium cam on stock 243s and 346 cubes.
If you had a cam in the mid 230s and ported heads then yeah I'd expect more, but for a medium cam and stock heads those are good numbers.
How much do you expect to gain out of a 226/230 cam? It already went from 389 to 450, thats 61rwhp from the cam alone. I'd say that's a damn good bump in power from just a cam swap.
BlueBird346's Avatar
Are you complaining about it being too low? Thats damn good for a cam-only LS6!
Old 02-01-2012, 10:09 AM
FRiCK's Avatar
I'm saying that's high. Don't know how you could take my post otherwise. Lol
Old 02-01-2012, 10:12 AM
clonedws6's Avatar
Yeah i thought you meant low. I was like uuhhhh WTF?
Old 02-01-2012, 10:25 AM
LSX Mechanic
Damian's Avatar
I'm not sure what you're getting at here, but you do know that Corvette's dyno less than most solid axle cars right?
Old 02-01-2012, 10:27 AM
clonedws6's Avatar
If my gto dynos anywhere near that i will literally **** a brick. I got the bigger eps cam.
Old 02-01-2012, 10:31 AM
FRiCK's Avatar
Its clearly a dyno error. These are max effort cam/ AFR, TFS headed #'s...
I was thinking it'd do roughly 430/400...
Old 02-01-2012, 11:11 AM
ZGLASS's Avatar
Yea you made the same power and more torque then my c5z06 don't think so. I had a little more cam ported tfs 220's milled to 59cc and a ported fast 92/92 and I went 450/412. Deff some dyno error here. I would expect around 415/395 would be more realistic.
Old 02-01-2012, 11:18 AM
FRiCK's Avatar
Is this a joke? Lol
Old 02-01-2012, 12:32 PM
MikeG's Avatar
Did it make those numbers on one pull or multiple pulls? The HP is high, but more believable than the TQ, but since the TQ is incorrectly high, the HP would follow.
Old 02-01-2012, 12:56 PM
FRiCK's Avatar
Multiple pulls. As he tuned it got higher. They go hand in hand so yes.. One would follow the other. The HP is high but who knows it could be a freak, but the tq? Absolutely not....
Old 02-01-2012, 01:20 PM
LS1 Tech Administrator
Patrick G's Avatar
While the gains seem a little high on paper, how does it feel on the street? Does it feel like 60 rwhp or more like 30? For what it's worth, that's a really good size LS6 cam for offering power gains with good street manners. Still, gaining 61 rwhp over an LS6 cam is a bit much. The trap speed at the track will tell the real story.
Old 02-01-2012, 01:46 PM
FRiCK's Avatar
Still breaking in the clutch... Trying to not go WOT on if for at least 3-400 miles. On the last pull of the night with the cut outs open for grins the clutch started to slip. The new LS7 only has 100 miles on it.
That's what I thought, what should it be trapping at that power level? Take dyno #'s with a grain of salt and the real test is the track, you just can't get that thru to some people tho... But is there anything wrong with wanting some consistency with these damn machines?! Lol
We shall see...
Old 02-01-2012, 05:49 PM
BayAreaSS's Avatar
He can test it out against me. And a 450/434 c5z at sac raceway should trap 124-126
The dyno was happy thats for sure
Old 02-01-2012, 05:58 PM
Theblacknightls1's Avatar
Why is that? Because I seriously thought vetts Dyno higher.
Old 02-01-2012, 06:04 PM
LSX Mechanic
Damian's Avatar
TQ tube, rear mounted trans, IRS, half shafts, etc.
Old 02-01-2012, 06:06 PM
outkast6991's Avatar
Irs would be the reason
Old 02-01-2012, 06:09 PM
Oh ok. Thanks
Quick Reply: C5 Z06 Pat G/EPS 226/230 cam only, makes 450/434??????????
