Just got back from the dyno
Old 03-30-2011, 08:03 PM
splitfinger09's Avatar
Default Just got back from the dyno
Setup
TrickFlow As Cast 220cc Cylinder Heads- 3.90 Bore
Fully Assembled Including .650 Lift Springs
Mill to Desired Compression-61cc
Hardened Pushrods
228/230 .588/.592 112 LSA Camshaft
Comp Trunion Kit
GM MLS Head Gaskets
ARP Head Bolts
FAST Intake Gaskets
Front Cover Gasket
Front Cover Seal
Waterpump Gaskets
GM Crank Bolt
Powerbond 25% Underdrive Pulley with Gates Belts/GM Bolt- F Body
Comp Drop In Hi Performance Lifters
Katech C5R Timing Chain
Melling Hi Volume Oil Pump for LS Engines
SVO 42lb/hr Fuel Injectors
GM MLS Exhaust Manifold Gaskets
Poly Motor Mounts
Kooks 1 3/4 LT's
LS6 Intake
TSP 3'' True Dual Exhaust
426 HP 413 TQ
What you think?
Old 03-30-2011, 08:05 PM
msydow's Avatar
what trans and gears do you have?
Old 03-30-2011, 08:07 PM
m6 3.42
Old 03-30-2011, 08:13 PM
msydow's Avatar
seems kinda low. i made 420/395. with an MS4 fast92/PTM 92 and stock 853 heads. prob just the dyno though. many people dont know that chassis and engine dynos are actually used for disappointing people that just pent a bunch of money on their cars. numbers dont matter. how does it feel? got any vids?
Old 03-30-2011, 08:27 PM
Yeah I was hoping for 450hp as it seemed so many people were getting that no prob with that setup. I am pretty happy with the torque though. It pulls very very hard. traction is def an issue. Im happy with it so I guess thats all that really matters.
Old 03-30-2011, 08:34 PM
msydow's Avatar
long as you're happy. you do the install?
Old 03-30-2011, 08:35 PM
of course def was a rewarding project. I was just happy it ran let alone put down the numbers it did.
Old 03-30-2011, 08:41 PM
msydow's Avatar
ha ha that was good for a laugh.
i do all my own stunts errr uh work too
just ordered my buddies TSP tsunami
cam and other misc crap to put new lifters
in it.
post up a vid of the traction issues... maybe we can
help diagnose that problem....
Old 03-30-2011, 09:23 PM
i do all my own stunts errr uh work toojust ordered my buddies TSP tsunami
in it.
lol yeah thats how feel too. As far as traction goes im thinking its just my stock suspension with that amount of power is not gonna cut it. I have nitto DR but they have about 12k miles on them so im sure there about done. Next mods are full suspension inc a 9 inch and a new clutch.
Old 03-30-2011, 10:00 PM
itsslow98's Avatar
do a FAST intake and i think youll see some great gains.
Old 03-31-2011, 08:01 AM
LS1Tech Sponsor
Slowhawk's Avatar
Thats a really nice curve. Screw the peak #'s. It makes 400+hp from 5200-6700rpm.
Old 03-31-2011, 09:37 PM
Mazzenger's Avatar
Looks good!
Old 04-01-2011, 07:07 AM
LS1Tech Sponsor
hellbents10's Avatar
I agree with Slowhawk, looks like a great curve! Should run really well at the track.
Old 04-08-2011, 07:34 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
if the red line on the air/fuel graph indicates 13.1 AF, then is looks real lean, especially up top
Old 04-08-2011, 07:57 PM
bayer-z28's Avatar
Prolly the LS6 intake holding back a couple horses.
Old 04-08-2011, 08:49 PM
1989GTA's Avatar
"if the red line on the air/fuel graph indicates 13.1 AF, then is looks real lean, especially up top"
Exactly what I was thinking.
Old 01-01-2012, 11:13 AM
So what should I tell my tuner? The car is running pretty rough. By rough I mean it back fires at high rpms and the car feels like it shutters real bad. Also when pulling out in first gear the car feels like it lugs really bad then kind of comes alive at about 2500 rpms...
Old 01-01-2012, 11:47 AM
BrntWS6's Avatar
Just curious, do you have an aftermarket fuel pump? If not do you feel you have the need for one? I've got H/C/I and wondering if I should install one.
Old 01-01-2012, 01:51 PM
No I do not. Im not really sure if I need one or not. Never really thought about it actually.
Old 01-02-2012, 01:20 PM
ls1 1990 VN's Avatar
I'm not up with what an F/Body fuel pump flows but with the power you're now making it will be a wise choice to upgrade.
Quick Reply: Just got back from the dyno
