2002 SS Heads & Cam
Old 01-28-2012, 11:58 AM
Tyler_PinkertonZ28's Avatar
Default 2002 SS Heads & Cam
I just got my car back after a heads/ cam swap. I was hoping for a little above 400rwhp, but the torque really surprised me. I'm definitely happy with it. What do y'all think I could do to break 400?
The set up is:
224/224 .591 112+4 Comp Cam
Lingenfelter Ported 853's
BBK Lt's and Y pipe
SLP underdrive Pulley
Stock Dual/Dual muffler with CME tips
Old 01-28-2012, 12:10 PM
Bramlok's Avatar
Not bad numbers but I would have expected that setup to make a bit higher numbers. There are cam only cars with bolts ons that make higher numbers. But I guess the important thing is how it drives. You can always take it to the track to see what it runs.
Old 01-28-2012, 12:18 PM
My thing with the cam was, I wanted a smaller DD friendly cam because I drive the car up to 70 miles a day. If I would have gone with a bigger cam, I'm sure I could have had 410-430 rwhp, but I wanted Hp all through the power band and torque also.
Old 01-28-2012, 12:50 PM
Bramlok's Avatar
How does the car feel to you? I'm sure it's plenty fast.
With dyno numbers, you never know. You could go back another day and dyno over 400hp. There is always a little give or take on the numbers depending on conditions.
Old 01-28-2012, 12:54 PM
It feels good. It definitely pulls harder and feels faster. I haven't had a chance to really get on it yet, but im definitely satisfied with the couple of hard 1-3 gear pulls ive done. I have never had the car at the track, and probably won't take it, I just wanted a good street car that would be able to stand its own with most cars on the road. Mostly new camaros and mustangs. I hope its fast enough to do that.
Old 01-28-2012, 05:40 PM
98z8uup's Avatar
What intake do you have? A fast may get you to your goal of 400.
Old 01-28-2012, 07:15 PM
Stock ls6 intake. Idk if I want to spend $1000 to gain 10 hp in all honesty. Haha
Old 01-28-2012, 07:21 PM
Killer5.3's Avatar
Send your LS6 intake to LS2 portworks and let Cory port it. Ditch the BBK headers and Y and go with something better along with better muffler. Bet you would see at least 20-25 rwhp with those mods. Those are 1 5/8 and 2.5 in Y if I remember correctly.
Old 01-28-2012, 07:27 PM
Porting the ls6 sounds good. I would like to eventually go with a full kooks exhaust, including the true duals.
Old 01-28-2012, 07:30 PM
djfury05's Avatar
those are horrible numbers for whats done to it
Old 01-28-2012, 07:58 PM
I didn't think they were that bad. Where do you think I should be with those mods?
Old 01-28-2012, 09:17 PM
jrpimp00's Avatar
I only made 396 to the wheels with my combo and run mid 12's on shitty tires
Old 01-28-2012, 09:26 PM
MikeG's Avatar
Do you have a factory SLP lid? If not a lid would help. How about a ported TB? Have you done the free mods? Those are all super cheap and would be probably be worth an easy 15-20rwhp all together.
Old 01-28-2012, 09:50 PM
djfury05's Avatar
I feel like 405-410 at least. Those headers/y-pipe combo are really restrictive though. Engine needs to breath more.
Old 01-28-2012, 09:57 PM
Killer5.3's Avatar
I wouldn't say they are horrible, but definitely some power left with a few tweaks. Pacesetters and a Y with the flowmaster merge would be a not too pricey improvement and soemone would buy your BBK setup to recoupe some of your $$. Better muffler, ported LS6 and throttle body if you haven't done so along with ram air such as chris1313 should put you in the 415 range at least maybe a little better.
Old 01-28-2012, 10:05 PM
garygnu's Avatar
good numbers ,you mite benefit from a better cam.
Old 01-28-2012, 10:10 PM
Killer5.3's Avatar
He is a convertible so heavy car. I would stick with the 224 cam and look for power elsewhere. He needs good low , midrange and avg power to move all that weight.
Old 01-28-2012, 11:08 PM
SS-ROB's Avatar
Who did the tune??
Old 01-29-2012, 07:15 AM
Wow, this took off last night. To answer the questions, the lid is a stock blackwing lid. I will look into some replacements. I'll check into headers soon, but I need a new rear right now, so that may be put in hold for a few months. The tune was done by Mike Bruce of B&B Corvette in Columbia, SC.
Old 01-29-2012, 08:44 AM
reeperz28's Avatar
Get a cutout . You will be suprised at your gains.
Quick Reply: 2002 SS Heads & Cam
