Wavy Dyno Graph?
Old 02-06-2012, 04:34 PM
mike171562's Avatar
Default Wavy Dyno Graph?
Got a re-tune the other day since i put in a stall and 243's, Tuner told me I had a slight misfire under load that was probably ignition related and the Graph had a wavy hp curve
Plugs are NGK's and were changed with the wires about 20K ago
My coil pack wire has a small nick in it, so I'll start by fixing that and changing the fuel filter
Anybody had a graph look like this before?
Old 02-06-2012, 07:40 PM
litle88's Avatar
What's your compression and what Ngk plugs are you using?
Old 02-06-2012, 07:59 PM
LS1Tech Sponsor
Slowhawk's Avatar
Looks like a problem with the pickup wire for the dyno. Not a car problem.
Old 02-06-2012, 09:11 PM
mike171562's Avatar
Running the tr55s, not sure what the compression is.
Old 02-08-2012, 07:19 AM
Sarg's Avatar
Smoothing of 1 probably has something to do with it
Old 02-08-2012, 07:37 AM
mike171562's Avatar
Its hard to see in the pic, but smoothing is at 5, a/f was at 12:1
Old 02-08-2012, 08:09 AM
Sarg's Avatar
Is it? On my phone it looks like a 1. Hard to see as the mobile sight squashes pictures.
Old 02-09-2012, 05:09 PM
mike171562's Avatar
Yes, and the funny thing is, i cant tell any misfires when im driving. It shakes a little at idle, I believe thats just the cam and the poly mounts.
Old 02-10-2012, 01:39 PM
mebuildit's Avatar
Sampling rate should of cleared that up too.
Old 02-11-2012, 09:43 AM
KC Henry's Avatar
^This.
Mine did the same thing, and my Tuner said it was the pickup as well. https://ls1tech.com/forums/dynamomet...ideo-pics.html
Quick Reply: Wavy Dyno Graph?
