383 tfs225 new Dyno numbers - LS1TECH
Thread Tools Search this Thread
Old 03-04-2012, 08:40 PM   #1
99slobird's Avatar
Default 383 tfs225 new Dyno numbers
Well after about two months of waiting on parts I finally got my car on the Dyno. I have a 383 ms3, ported 241s, 102/102, 1 3/4 headers and 2.5 x pipe and a tight 2500 converter. Car made the numbers in my sig. The changes. Made was 1.7 roller rockers trick flow 225 heads 60cc chambers and around a 4 thousand converter and I put tsp 1 7/8 headers on but my 3 inch exhaust didn't come in in time so I put the 2.5 exhaust back on ..... Ok lane culver tuned the car from Lacey springs on a nitrous tune the car made 440 hp through the 12 bolt na and on a 150 shot with c16 in the stand alone it made 616 hp with the before setup on the same jets pulling off the rail it made 548hp. We stepped up the the nitrous jet to a 82 and the cars last pull made 663hp and 745 torque There's my results. I hope it puts me in the 6son motor and 5s on the spray in the eighth
99slobird is offline   Reply With Quote
Old 03-04-2012, 08:45 PM   #2
Nice numbers and similar to what I put together except I went vic jr/4150 and a larger cam. Hoping to make it to the track soon and see just how much the tsp 2.5 5.3's leave on the table.
thedudeZ is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
New numbers removing cme tip (403ci-AFR225s) quik01ss Dynamometer Results & Comparisons 5 10-07-2013 10:09 PM
Got on a real Dyno finnally.. 1998silverbird Dynamometer Results & Comparisons 18 01-14-2013 12:27 PM
Auto TRex dyno. Low numbers? PBMGOAT04 Dynamometer Results & Comparisons 30 12-23-2012 10:08 AM
383 trick flow new numbers 99slobird Generation III Internal Engine 9 03-07-2012 03:35 PM
Finally got the 408 Grocery Getter Dyno results TXCAMSS Dynamometer Results & Comparisons 41 06-14-2008 12:41 PM
Tags
25, 383, culver, dyno, hp, lane, ls1, ls1tech, ms3, numbers, results, shop, tech, tune, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
