228/232 Cam only results w/ graph
I wanted a milder cam that drove like stock, and made a lot of under the curve tq with a nice powerband... and without spinning it to the moon to make power. I went with a Spartan cam... It makes peak power at 6250, drives very easy, and plenty of tq down low. My car is set up for taking corners, not straight line speed. Mods:
228/232 .581 .585 112+4
Pacesetter LTs and ORY dumped
Lid, LS6 intake
Everything else is stock (thats relative to power) with 115k and it has heavy 18s with wide Toyo 315s.
I am very pleased with the results. I am sure there is more left in the tuning, but she sure does run good now.
Lid, LS6 intake
Sam tuned it. I don't think its dead on, but pretty close. I am no tuner, though. He also said that the coil packs being loose on my car could cause the waviness, so ill try to get that taken care of aswell.
LS1 Tech Administrator
I agree. Great cam.
Not necessarily. With 10% ethanol (most likely what's in the tank if it's in the DFW area), I've found best power with A/F ratio around 12.4:1. With 100% gasoline, it was closer to 12.8:1 to make best power, but you have to adjust fuel to air ratios to match the fuel in the tank. Ethanol has a much lower stoich than gas.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I agree. Great cam.
OP, Great numbers for a cam only car. Spartan suggest that came to me after I did my EPS cam.
Got a graph the the hp/tq the same numbers, that one makes it looks like the tq drops like I rock. Untill I noted the "300" on the left was not tq, at 6200 looks really low. ha
Why not SAE? I rarely see over 1.01 correction, how did the STD compares to SAE in that weather?
Yes, Pacesetter ORY with flowmaster merge.
That is the graph Sam printed out for me. I honestly don't know how/if the SAE numbers differed. Im sure they would have been a little lower but not much. If calibrated correctly its a 2.6% difference I believe. I need to go back so he can touch up my idle, so Ill look into getting an SAE graph.
