CSP Built LS2 GTO, 227deg HR, Ai 226cc CNC'd 243's - 476/409 - LS1TECH
Thread Tools Search this Thread
Old 04-07-2012, 02:43 PM   #1
Smile CSP Built LS2 GTO, 227deg HR, Ai 226cc CNC'd 243's - 476/409
A northeast shop, CSP, has been getting great results with their packages that include our CNC'd GM 241, 243, etc. heads. Thought you guys might like to see some as I sort through results guys have been kind enough to send in.
LS2 M6 GTO
Primary details:
Ai 226cc CNC work on GM 243 heads
Lunati 227/235 .620" 114
Ported GM LS2 Intake Manifold
Full Exhaust w/ Cats
LS7 Clutch
Built & Tuned by Andrew @ CSP
Original GTO forum thread by CSP:
http://www.ls1gto.com/forums/showthread.php?t=436788
Hope you guys like it!
-Phil
Advanced Induction is offline   Reply With Quote
Old 04-08-2012, 09:01 AM   #2
reeperz28's Avatar
Pretty awesome numbers on stock ls2 intake ported. Hope to get close to those numbers with my 243 AI setup
reeperz28 is offline   Reply With Quote
Old 04-08-2012, 09:18 AM   #3
Gordon0652's Avatar
Nice numbers!
Gordon0652 is offline   Reply With Quote
Old 04-08-2012, 02:11 PM   #4
s346k's Avatar
holy **** look at that tq curve.
s346k is offline   Reply With Quote
Old 04-11-2012, 06:04 PM   #5
LS1Tech Sponsor
And it drives really amazing. Just like stock.
We've got a special going on for all LS engines for the head install. We will send out our cores to get ported for you so you have minimal downtime - just the time it takes to install and tune. This does not apply to the LS7 (as we don't have a set of those heads). We have LS1, LS2, and LS6 heads in stock ready to be sent out.
You can combine this special with a cam install and save some pretty good labor there!
andrewzpsu is online now   Reply With Quote
Old 04-16-2012, 07:12 PM   #6
Smile
Quote:
Many guys do - some built by highly experienced shops tend to do it out of the gate, while others end up working at it to identify areas of their setup they can refine to get things up to potential. Either way, the potential is there.
I'm sure it drives quite well, I try and stick with cams in this size range since they lope a bit, but with proper calibration have essentially stock manners. That is especially the case when guys retain OE clutches.
If we schedule work ahead of time knowing when heads will be delivered, especially if it is machine work only, then I can typically turn them around in far less time than normal.
Thanks for your hard work on it!
-Phil
Old 04-28-2012, 06:03 PM   #7
LEO
LEO's Avatar
I like small cams that put up big numbers. It's all win.
LEO is offline   Reply With Quote
Old 04-30-2012, 05:47 PM   #8
Great results for the setup!
yonerhottlt1 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Advanced Induction 230cc CNC'd TFS' & HR on LS2 C6 - 488sae/497std Advanced Induction Dynamometer Results & Comparisons 15 02-28-2013 02:40 AM
Advanced Induction 226cc 243 Heads xssive Parts Classifieds 10 12-15-2012 04:35 PM
CSP LS1 GTO w/ Ai 219cc CNC'd 241's - 455/397 Advanced Induction Dynamometer Results & Comparisons 8 06-05-2012 07:53 PM
Heintz Racing C5 w/ Ai 226cc CNC'd 243's Advanced Induction Dynamometer Results & Comparisons 21 05-30-2012 04:30 PM
Thunderchicken w/ Advanced Induction 21deg CNC'd TFS Heads & HR Dyno Results Advanced Induction LT1-LT4 Modifications 104 04-23-2012 02:18 PM
Tags
227, 235, 243, advanced, ai, csp, dyno, gto, heads, induction, ls1, ls2, lunati, results, reviews
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
