My 6.0L on the engine dyno
Carb'd 6.0L
mildly worked L92 heads and VicJr,
Bret Bauer Racing cam.
Land & Sea engine dyno
STD correction factor
I had this engine on the dyno in Feb and posted it in the carb section, not sure why I didnt post it here, since most guys stay out of the carb section, lol.
here is a link to the rundown on the engine:
https://ls1tech.com/forums/carburete...gine-dyno.html
here is a shot of the dyno sheet:
[QUOTE=3pedals;Obviously I don't want to run it any higher than necessary on the oem bottom end/ heavy l92 valves, lol[/QUOTE]
Hmmmm, that was with the factory stock L92 valves? Pretty good then and no reason to upgrade to lighter valves if so.
have you put it on a chassis dyno yet? Just curious... What the weight of the car?
We are limited to ~8,000 rpm with my setup due to factory pcm right now, what are you running, belt drive dist? Or the front cover ford dist?
For comparison we made 540 rwhp @ 7200 rpm, and it doesnt fall off much up to 7900, car trapped 136.7
No chassis dyno. Car weighs close to 3425lbs w/ me.
I am using MSD 6012 box, no distributor.
I have had it to the track 1 time with this combo, and I made 5 passes, NONE were clean passes, but the best pass was 10.91 @ 130 with a disgraceful 60ft. spun HARD all the way through the 60
I think there might be 1 or 2 mph left in the combo, but I KNOW there is alot of ET left in it.
Your car is running Big mph!, using a stick too! I LIKE it.
Gained 110 rwhp, and now in destroying clutches, blowing the tires off, etc... And only going .3 faster.
I saw on YB you have the ram 470cw, and 5135 disc? What fw are you using? and is that disc part number 1363, (1 1/8"x26?)
Im thinking about buying a mcleod 360903 bb/long PP and a ram 1363 disc.... and building a hybrid clutch.
