98 Camaro LQ4 370ci Tea stg2 Ls6 Fast102
Old 05-08-2012, 11:07 PM
Go On 3's Avatar
Default 98 Camaro LQ4 370ci Tea stg2 Ls6 Fast102
just got dyno tuned today thought i would share my results...
98 camaro
LQ4 6.0 370ci forged
TEA stage 2 ls6 heads
Trickflow stg 3 cam(228/230)
Fast 102, NW102TB
Pacesetters 1 3/4coated
Xpipe dumped at axle
A4 Trans was bought used from Trickflow and work done to it is unknown(had a shift kit already installed when recieved.. was told it was pulled from a shop car/test car)
10bolt 3.73s
put down 440/450 (superflow dyno)
the afr went pretty lean after 5500, at first thought it was a wideband issue because o2 readouts were not acting up but maybe a fuel pump issue... i have an extra 255 im going to swap in. i will be returning in a week or 2 to get a few more runs in...any other ideas/things to check would be appreciated
Old 05-09-2012, 06:22 AM
MikeG's Avatar
What injectors are you running? Those are solid numbers considering the smallish cam, superflow dyno, and fueling issues.
Old 05-09-2012, 06:54 AM
30th t/a's Avatar
nice looking power curves!
Old 05-09-2012, 07:06 AM
reeperz28's Avatar
Good looking car and sounds like a good combo. Get those issues straightened out it will be a killer ride!
Old 05-09-2012, 08:49 AM
Go On 3's Avatar
42lb Injectors and racetronics fuel pump.
Old 05-09-2012, 12:18 PM
Midnight02's Avatar
Solid numbers. I have the same cam in my 346 and was quite impressed with the power under the curve.
Old 05-09-2012, 05:18 PM
Go On 3's Avatar
thanks everyone. i was hoping to take it out tonight with a pressure gauge attached to see what it was doing but it started raining hopefully tomorrow will be nice i really cant wait to get everything 100%
midnight02 what kind of numbers did ur car put down? na? spray?
Quick Reply: 98 Camaro LQ4 370ci Tea stg2 Ls6 Fast102
