looking for a tuner & guess my hp/tq??? - LS1TECH
Thread Tools Search this Thread
Old 05-31-2012, 06:12 PM   #1
Default looking for a tuner & guess my hp/tq???
started my car yesterday after the heads and cam. I have stock 799 heads, 236/249 601/608 113lsa cam, walbro 255 fuel pump, ported ls6 oil pump, slp air lid, long tube headers, texas speed x pipe, and slp loud mouth mufflers built a4 with my stock ten bolt. should have my ls6 intake in a week. Then im getting it tuned. wondering where I should be with hp/tq at the wheels.
also debating on where to get it tuned. maybe performance by Joe or tim that use to work at red line performance. any suggestions or experiences with one of them two or any other tuners near st.louis?
musclecarsrock68 is offline   Reply With Quote
Old 05-31-2012, 07:19 PM   #2
really? no one can give me an estimate or recommend a tuner near st.Louis?
Old 05-31-2012, 10:02 PM   #3
A.R. Shale Targa's Avatar
Looks like PBJ did a nice job on the jeep in your area
I'd guess 430/390 on power.
A.R. Shale Targa is offline   Reply With Quote
Old 05-31-2012, 10:22 PM   #4
MikeWS6's Avatar
415-435 / 380-400
MikeWS6 is offline   Reply With Quote
Old 05-31-2012, 11:25 PM   #5
No way 430hp with stock heads and an A4. I would guess high 300s (365-385)
OP, did you check PTV clearence? Seems like alot of duration in that cam.
badazz81z28 is offline   Reply With Quote
Old 06-01-2012, 05:20 PM   #6
even tho ls6 corvettes were rated at 405 with a smaller cam and more restrictive exhaust?
and i did not, i was told i shouldnt have to worry about it. but how do i check it? and ive already ran the motor and seem to have no issues. does that mean it should be ok?
Old 06-01-2012, 05:26 PM   #7
Exeodus's Avatar
That 405 rating is flywheel, the guys are guessing rear wheel HP numbers.
Exeodus is offline   Reply With Quote
Old 06-01-2012, 05:52 PM   #8
Quote:
so whats that corvettes rwhp rating?
Old 06-01-2012, 05:56 PM   #9
407rwhp
got milk?? is offline   Reply With Quote
Old 06-01-2012, 06:00 PM   #10
Quote:
Originally Posted by got milk?? View Post
407rwhp
with the same heads, a smaller cam and more restrictive exhaust and a factory tune. so i should be making more then that right?
Old 06-01-2012, 06:05 PM   #11
mkvamso's Avatar
just get it tuned
Dont get hung up on numbers, they dont mean anything. Two cars with the exact same h/c/i/e can produce pretty different numbers.
mkvamso is offline   Reply With Quote
Old 06-01-2012, 06:37 PM   #12
slammedc5's Avatar
Stock c5 zo6s dyno around 360 at the wheels on a dyno. Thru a 6 speed and transaxle type rear end tranny mounted to rearend, and independent suspension. Yours is an auto thru a 10 bolt
slammedc5 is offline   Reply With Quote
Old 06-01-2012, 06:55 PM   #13
mark21742's Avatar
When I ran a 238/242 .595/.595 lift cam I pulled the heads to port them and had marks where the valves kissed the pistons.....I got lucky and didn't bent any valves, but you NEED to measure your ptv with that duration cam shaft or you are asking for trouble
mark21742 is offline   Reply With Quote
Old 06-01-2012, 10:16 PM   #14
I'm no ls expert by any means but im thinking 405-410rwhp with an A4
Zombiesoldier is offline   Reply With Quote
Old 06-17-2012, 11:55 PM   #15
im going to get it tuned by pbj at 9am tomorrow, will post up numbers and the graph if i can figure out how to get the graph up.
Old 06-18-2012, 12:56 AM   #16
Blk98Vert's Avatar
If you hit 400 ill be shocked
Blk98Vert is offline   Reply With Quote
Old 06-18-2012, 10:34 AM   #17
Quote:
why would that be so surprising?
Old 06-18-2012, 01:34 PM   #18
I8UR4RD's Avatar
Im almost certain its between 390-405rwhp. tq is prob 365-385. get it tuned. the number doesnt matter until they hand you the time slip.
I8UR4RD is offline   Reply With Quote
Old 06-18-2012, 08:31 PM   #19
At the end of the day it made 371rwhp and 346TQ but there is more room to improve, but i had a misfire at 5500 RPMS that would randomly show up and then dispersal. and my passenger o2 sensor has a wiring issue with the extensions the guy before me put in.
Joe says thats roughly 415 through a 6 speed or 475 at the crank. also found out i have a 4000rpm stall not the 3600 that the guy told me. headed to the track Wednesday to try and beat my best of 12.8
Old 06-19-2012, 01:40 AM   #20
Blk98Vert's Avatar
Told you. Dont get hung up on the numbers though
Tags
01, bolt, diablo, dyno, gto, louis, mo, ons, performance, predator, redline, review, slp, sport, st, trans, tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
