l33 cam only at 8.6psi
Old 09-27-2012, 08:00 PM
chiaj144's Avatar
Default l33 cam only at 8.6psi
Just got off the rollers. Put down 504rwhp/670lbft at 8.6lbs through a th400. More details and graph to follow. Added one degree of timing and the car made 10 more horsepower but lost over 50ftlbs so I backed it back down.
Old 09-29-2012, 12:44 PM
30th t/a's Avatar
wow nice numbers from a little 5.3 thru a th400! Thats low boost too!
Old 09-29-2012, 12:46 PM
Sales1@Texas-speed's Avatar
Should be a stout setup for sure. What cam did you decide to run if you don't mind me asking?
Old 09-29-2012, 08:01 PM
chiaj144's Avatar
I bought it off of sprayed01 on the forums here. Specs are 226/228 .585/.592 lift on a 115+4 lsa. I'm also running an ls1 intake and head studs, everything else is stock.
I got the Holley coils hooked up and a boost controller on it now and I will be hitting up the dyno this coming Friday for some 14-15psi pulls and then I'm off to the track on Saturday. First time to the track with 2 degrees less timing it went 126mph and it wasn't pulling until after the 60' mark.
Old 09-30-2012, 12:11 PM
a-low's Avatar
Very impressive tq numbers. Turbo or charger?
Old 09-30-2012, 06:19 PM
chiaj144's Avatar
Mpt70.
Old 10-03-2012, 01:52 PM
chiaj144's Avatar
I made a mistake on the torque number it was 617 not 670.
First pull 161kpa bleeding down to 152
Second pull 142kpa bleeding down to 135kpa.
I need to figure out if my wastegate isn't closing. I'm losing boost and not getting to max boost until 5000rpm.
Old 10-05-2012, 02:21 PM
chiaj144's Avatar
Update 13psi and she put out 587/697. Just shy of 13psi bleeding down to 10psi.
Old 10-14-2012, 04:41 PM
mikesanto70's Avatar
Holy guacamole!!!!!!!!! What car do you have it in and what type of tubo manifold set up are you using.
Thats the #'s I'd like to make. Just picked up a 99' Formula A4 w/ blown engine and I'm going to do a L33 or LQ4/9 if I can find one reasonable.
Will the L33 make more boosted power than the 6.0, I read some mo mo's thread saying that poop but I cant see it!!
Old 11-09-2012, 11:10 AM
chiaj144's Avatar
Sorry I somehow missed your reply. It's in a 3000lb mustang and I'm using truck manifolds flipped backwards. As far as a 5.3 making more power than a 6.0 I think it really depends on the entire combo. It you have both engines with the proper setup the 6.0 will make more power every time. If you try to run a 6.0 with a little turbo it will make more useable power on a 5.3.
Quick Reply: l33 cam only at 8.6psi
