1988 Monte Carlo SS LS7 stock short block H/C/I belts out 660 RWHP N/A on 92 Octane!
The following users liked this post:
fasttenz (06-25-2022)
#43
Good work John, very impressed! Try shortening the primary length, and increasing the diameter, if you are still on your original headers you made years ago!
#44
Sweet ride sir. Those G-bodies always look gangster evil. That is the template for how I would do an older car right there. Big-inch, big power N/A LSx, I love it.
Heres another one I look at for inspiration:
http://www.pro-touring.com/showthrea...journal-thread
BTW, how much power do you think is possible with a N/A LSx on pump gas? Do you think you would benefit much from some bigger heads and little longer stroke? 660rwhp is ALOT N/A. I bet that things so violent.
#45
#46
Mr John, a question thats been sorta bugging me lately, and since you have a very bad N/A LSx streetcar, is there anyone out there with a N/A LSx street car on pump gas in the 8s? E85 not included? Not worried about how gutted it is or what car its in but just curious...
#48
On a side note, is that bottom end safe @ 7600?
#49
Awesome build/results..!!!!! My old man still has his white SS since new in 84.
I'm trying to convince him to do an LS swap. Just a thought..could your dyno
waves be a valvtrain harmonics issue caused by pushrod deflection ??????
Seems the lobe size and lift #s could possibly need a 7/16" tapered to 3/8" @
the ends....heavy I know but there is some validity to the taper reducing the
stored energy resonance inherent to solid roller valvetrains...great job again !!
#50
Thanks! No, my pushrods are 0.120" wall thickness, they could hold up a house! I really thinnk the harmonic's are electronically induced to the dyno pick-up's some how and these PR's are really about as large as you can reasonably stuff in there (I had some minor clearancing to do as it was!).
If your dad wants his car to really haul, you know what to tell him! That's cool that he still has it!!!
Just a thought..could your dyno waves be a valvtrain harmonics issue caused by pushrod deflection ??????
#51
Those Monte SS cars simply make bad *** hot rods. Great lines.
Maybe I missed it. Stick or auto? 12 bolt or ???? The 8.5 is probably just fine....with some tweaks if that is what's in there.
Are you going to run drag radials or real slicks? Weight?
I drive the Nova in my sig to the track always. That is the fun part.....trailer? What's that?
Will you run at Bremerton?
Way cool, this older dude likes it!
Ron
Ron
#52
Weight?
Thanks again for the props Ron!
#56
Updates?!?! Track times? Bueler? Bueler?
#57
And...
#59
