Cam Only + 175 Shot
Mail order and I did some tweaking with HP tuners on the dyno. How is the motor AFR run? Any suggestions on what I should change or be looking to change?
I would have a professional tune this car before you do some serious damage to the motor.
The motor only run is perfectly safe, although the AFR is very rich and not conducive to making power. It's ok up to 4500rpm, but after that there's no need for the curve to dip into the mid 11s N/A.
I agree with this while running on the juice, looks dangerous. Lots of knock and the AFR gets too lean from 4500 to 5200. That's peak torque and it's significantly more dangerous to run lean there. You're ok running it off the juice, but don't spray anymore until you get it tuned.
