LS2 GTO/V.2 Polluter/PRC As cast 225cc/Fast 92 makes 500rwhp!!!
Just think this set-up has:
-As Cast cylinder heads
-LESS than .600" exhaust lift LESS! Less is MORE in this case!
-UN ported Fast 92!
-STOCK TB, YES A STOCK TB!
-Still has FULL exhaust on the car!
-NO EWP!
-Bolt on's are full exhaust, a Vararam intake and an UD pulley...that's it!
This set-up can be replicated VERY easily people!!! 500rwhp on a stock bottom end used to be a dream to most people. Only guys with names like Mamo, Gigliotti, Curtis, Tooley, Pat G and the likes have crested 500rwhp with a cathedral port 3.622" stroke engine. Even though Tick Performance is the name behind this build, you guys that do this in your garage on the weekends can put together a package like this just as easily and do the same.
We are not trying to re-invent the wheel. We are not trying to say we are the only ones to ever achieve this power, BUT it's not as hard to obtain as it once was thought to be. With the right camshaft, compression and simple little parts it can all be done again.
We have a few more new customers that are going to be doing set-ups just like these very soon with our 112lsa V.2 Polluter cam to boot. Should be interesting to see how they fair as well!!!
-UN ported Fast 92!
-NO EWP!
Back from the dead.
Martin I am looking at almost the same combo and was just undecided on the cam. This may be the ticket. How well do you think it would perform with
Tms370 forged pistons
Prc 225 heads
Ls6 intake ported tb. Will upgrade to fast down the road not soon
1 3/4 headers with true duals may step up to 1 7/8
M6 ls7clutch and flywheel
I have searched for hours and this tread is closest to what I want to do. What kind or mileage do you think it would get?
I hope you are still watching this tread lol
Prc 225 heads
Back from the dead.
Prc 225 heads
Prc 225 heads
Mileage I assume you're referring to gas mileage?
Thanks for the reply.
Yes fuel mileage. Wile it is not the most important thing I would like to be able to keep it in the 20's on the highway. Stock 3.42 gears.
Do you happen to remember the size injectors this combo used?
How long after ordering would the cam take to come in?
Kind of shocked that this tread only got two pages of attention. It's an awesome build with great numbers and fairly budget friendly. Great combination.
LS1Tech Premium Sponsor
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
#34
I know this is reviving a thread from the dead, but does anyone know what this car ran at the track? I have a similar setup on my 06 GTO but with a stock intake instead of a fast. I had mine dyno'd with heads that flow very similar numbers (Stage 3 ls6 Patriot Performance heads), except with the new version of this cam that has .631/.610 lift, and I only made 450whp and 387tq and I have a hard time believing an intake and a .5 bump in compression will make that much more power. Now I know that all dyno's read different, but the best I can do at the track was a 12.4 at 113mph with an albeit shitty 2.996 60'. I know an intake will definitely help my car breathe a lot better, but I feel like my mph should definitely be more up there. I mean hell, my cam only (torquer V2) with bolt ons (factory short block) ran a 12.4 at 115. can anyone provide any insight to this? My current short block is a thompson motorsports forged internal stock cube ls2 motor with -2cc pistons as well, but running around the same compression as stock (due to the +.006" piston to deck height) from my calculations. I've also got full bolt ons with 57 lb injectors as well. Thanks for anyones help!
#35
__________________
#36
If your 60ft is really 2.99 then that is a lot of your low trap speed. Some people say spinning equates to a higher trap but my car always traps higher with a lower 60
#37
Just curious, doing a similar build/setup to this. While I have not broke down the engine and installed my Polluter v2 yet, [happens in end of april] I was wondering if you recall what pushrods and lengths/walls that were used?
#39
Your numbers seem pretty close to be honest. The intake is 15-20rwhp easily and the extra compression is another 10 or so. That's not 50 but that puts you in the ball park of variance, tuning differences, and slight part differences. The weight difference in your rotating assembly might also equate to a little power difference as well.
#40
