408 LS3 top end Dyno results
Old 05-09-2016, 03:58 PM
  #41
KingPin1094's Avatar
So I just had to take the fuel tank out and found out that I have a stock fuel pump in my car. Not a 255LPH like i was told. Soooo not sure what this means exactly. Does it mean with proper fueling my car can make more power?
Old 05-09-2016, 04:46 PM
  #42
blk00ss's Avatar
Only if it's running way lean. If it's keeping the commanded AFR, then no.
Old 05-09-2016, 05:12 PM
  #43
Yea that makes sense, but for all I know it may not be able to keep the AFR above 6k rpm which is why my tuner shut it down and put the limiter there. I have an AFR gauge, if the car were together I would video it and see if it tapers off near higher rpms, but I just can't do that right now.
Old 05-09-2016, 09:02 PM
  #44
KW Baraka's Avatar
......if the car were together I would video it and see if it tapers off near higher rpms, but I just can't do that right now.
I don't know how much work you're doing with the car....but a 255LPH fuel pump ain't that expensive.
Since you've already pulled the stocker, I'd be inclined to install a 255 pump in place of the stocker and go from there.....
KW
Old 05-10-2016, 09:31 AM
  #45
KW
Oh yea I'm putting the 255 pump in for sure, if not only for added reliability.
Old 01-08-2017, 08:47 AM
  #46
mred's Avatar
i was thinking fuel pump as i was reading ALL of this thread,so what was the out come?
this motor should pull 7200 all day
Quick Reply: 408 LS3 top end Dyno results
