Cam install + bolt ons dyno
So I just got my car back from a cam install at Race Proven Motorsports and I must say they did an excellent job with my car. Top notch customer service and amazing work. I would highly recommend them to anyone. The car is awesome above 4000rpms and drives near stock at low rpms. Not to mention it sounds bad ***. My current set up:
2000 LS1 motor in a 1996 z28 Convertible
23x/23x 114 lsa with <.600 lift
LS6 intake
P&P throttle body
LT1 style cold air intake
BBK long tube headers + 2.5'' y pipe
M6 with stock 10-bolt 3.42
(I believe this is on a mustang dyno)
Before peak#s: 330whp 341wtq
After peak#s: 366whp 349wtq
Gained approximately 50whp at 6200 rpms
I think my stock cat-back may be holding me back a bit but the car is not a max hp effort as it is a weekend driven convertible that as of now looks bone stock. I am hoping to do heads when I am done with grad school (Ph.D in Biochemistry) which I believe should really compliment the cam liking to rev. Attached is a picture of the before/after dyno.
Thanks again to Race Proven Motorsports.
LS6 intake
P&P throttle body
Thanks guys! As I said I am really happy with everything. And it is probably a dynojet then, I wasnt sure. Jrenigar, how do you like the cut out? I have been going back and forth between getting one or a magnaflow catback.
Best sounding exhaust I have had on all 4 fbody's I have owned. It can be almost whisper quiet closed then sound like td's turned down in about 2seconds with the flip of a rocker switch. No rasp when a magnaflow bullet muffler is used before it right off the oryp either. Hard to believe but its true.
