Disappointing pull on the bottle
Old 09-13-2014, 05:36 PM
SoonerBrad88's Avatar
Default Disappointing pull on the bottle
Shop in town had a dyno day today so I figured I would throw mine on there and see what it did on and off the bottle. Well off the bottle I was pleased, it did 344/358. On the bottle(150 shot) it only made 434/425... I know a dyno is just a number and usually a disappointing one at that, but that seemed abnormally low especially the torque number. Im thinking it may have picked up a knock and pulled to much timing. I know the car runs good and even if 434 is right the track times are good in my book.
This was a dynojet, and it was about 60 degrees today. Anyone else think I may have had a problem or was it just one of those things?
Old 09-13-2014, 05:46 PM
1 Slow WS6's Avatar
What did the AF ratio look like?
Old 09-13-2014, 06:25 PM
HCI2000SS's Avatar
How much timing was pulled?
Old 09-14-2014, 01:29 PM
Fat Jesus 808's Avatar
how full was the bottle, how was bottle pressure?
Old 09-14-2014, 02:01 PM
luigiandme's Avatar
We need more details. Also, how is it being sprayed? Wet or dry? Plate, fogger, puck, direct port, money maker?
Old 09-14-2014, 08:45 PM
Sorry... its a wet nozzle kit, bottle had about 6lbs in it @ 950psi. It has 4 degrees pulled for when I spray. And I didnt get an AFR because my sensor went bad on mine and they didnt hook one up.
Old 09-14-2014, 09:28 PM
74u
74u's Avatar
Do you have a screen fitting at the Nitrous solenoid? NOS brand has them, not sure if other vendors use them.
Anyways, mine have gotten blocked with trash in the past and got to the point I couldn't even tell if my 125 shot was coming on. Creeps up on you...just gets progressively weaker.
Old 09-14-2014, 11:24 PM
Where is the screen located? The fitting going into the noid from the main line?
Old 09-15-2014, 08:15 PM
74u
74u's Avatar
Yes, the fitting that screws into the "in" side of the N2O noid.
Old 09-16-2014, 03:14 AM
I'll look into getting one of those! As for anything else, I think I'll pull a couple more degrees of timing and go from there
Old 09-16-2014, 10:18 AM
smurfkiller's Avatar
hmm without any kinda data logging its kinda hard to tell. might be worth the $100 or so to put it back on a dyno with all the senors hooked up and see what it does. could be power left on the table.
Old 09-16-2014, 10:23 AM
74u
74u's Avatar
No need to replace the part...it's just a metal screen. Clean if needed and reinstall.
Old 09-16-2014, 06:43 PM
I would think there's more left in it. I've run a few cobras that make a bit over 500 and put cars on them. It just doesn't make sense. I'll probably buy credits for hp tuners and use my buddys computer. See what its doing during a pull.... whats odd is I ran it the week before and it did just fine. Made clean hard pulls through each gear. Maybe it sitting still on a dyno, not getting the same amount of air changed something?
Old 09-17-2014, 11:06 AM
prob not , it takes some serious MPH to change the amount of air pressure going in the intake. in other words RAM AIR a positive pressure in your intake tract takes vehicle speed of 125+ mph. Spectre reported on their speedliner it was 205mph before RAM AIR was achieved.
Old 09-17-2014, 11:17 AM
1 Slow WS6's Avatar
What fuel pump are you running?
Old 09-17-2014, 12:19 PM
A Walbro 255
Old 09-17-2014, 06:56 PM
DietCoke's Avatar
10 times out of 10 shitty results are from a shitty nitrous tune or shitty jetting. Fix it before you blow your car up
Old 09-17-2014, 07:47 PM
mchdg86's Avatar
You only have to buy credits if you want to make changes to the tune. Data logging cost nothing.
Old 09-17-2014, 09:28 PM
Good to know!
I agree 100%. Thats why Im kind of taking my time and crossing my t's and dotting my I's
Quick Reply: Disappointing pull on the bottle
