EPS 234/246 FAST 92/92 PRCls6 9" MADE 448/398
Old 04-14-2015, 03:51 PM
getusumws6's Avatar
Default EPS 234/246 FAST 92/92 PRCls6 9" MADE 448/398
Dont have dyno sheet yet but can post some dyno video.
Build: 00 Camaro z28
*rebuilt ls1(1400 mi); stock rods, oe syle piston 3.905, arp rod bolts
*EPS 234/246 111
*PRC ls6 2.5 heads
*FAST 92/92
*fuel rails w 39lbs injectors
*TSP 1 7/8 headers
*double roller, Melling oil pump
*UDP
*solid MM
*SSRA
*Built 4l60e w/ YANK 4k (flashing at 4800 on dyno)
*Moser 9" w/ 4.11
*26" nitto DR at time of dyno
* TSP x pipe with bullets dumped
Car previously made 419/392 with ls6 intake as only change
NOW after FAST 92/92 swap and new tune, car made 3 back to back 448/398 pulls, i thought that was damn good through a stalled auto and 9".
pulled to 6700rpm then went flat to 7k.
Old 04-14-2015, 04:54 PM
sbf
sbf's Avatar
thats really nice power should be a 10 sec car.if u had a 10 bolt smaller stall and less gear your dyno numbers would be higher but slower at the track.but dyno is just a tool so good job man i bet it feels very strong
Old 04-14-2015, 04:57 PM
JROWS6's Avatar
what kind of dyno were you on?
Old 04-14-2015, 05:15 PM
getusumws6's Avatar
DynoJet
Old 04-14-2015, 10:43 PM
2002BLKWS6's Avatar
Are your heads milled any? What compression ratio are you running with your setup?
Old 04-15-2015, 03:27 AM
HCI2000SS's Avatar
Before and after on the same dyno?
Old 04-15-2015, 12:18 PM
JaSSon's Avatar
Very nice results fixn to have Geoff grind me up something for max 346 build
Old 04-15-2015, 12:41 PM
Rise of the Phoenix's Avatar
With an auto and a 9", I'd be very pleased.
Old 04-15-2015, 04:46 PM
getusumws6's Avatar
Heads NOT milled
Old 04-15-2015, 04:51 PM
getusumws6's Avatar
Was not on the same dyno. Same tuner, was very familiar with both dynojets (He tuned my car on both). He told me to be prepared to be disappointed because the dyno we measured on the for the new numbers, supposedly puts down lower numbers. Well, I wasn't .
Old 04-15-2015, 05:22 PM
HCI2000SS's Avatar
All the more impressive then!
Old 04-15-2015, 05:59 PM
Kingc8r's Avatar
How was your PTV clearance with those TSP heads? Impressive numbers I have the same cam but my car is still apart. I'm slowly buying parts but unsure of what heads to put on
Old 04-15-2015, 06:10 PM
Zmg00camaross's Avatar
Great numbers. I made 427 rwhp with that cam and fast 78, manual Trans help with the numbers. Was on a dyno jet.
Get that thing in there!!
Old 04-15-2015, 06:46 PM
HeavyMetl's Avatar
Remarkably similar results to my 347/AI226/ AI 236/242 cam results thru a 9".
I've trapped 122.8@3400lbs with a T56
Old 04-15-2015, 07:53 PM
Kingc8r's Avatar
Trying man, things keep coming up so I mod as I can. Getting there slowly lol
Old 04-15-2015, 08:55 PM
getusumws6's Avatar
PTV was good, I have valve reliefs on my new pistons.On the old stock flat tops though, I cut 50 thou. on each side.
Old 04-15-2015, 11:01 PM
Kingc8r's Avatar
How much was your rebuild? I've been debating between a stock rebuild and a forged build
Old 04-16-2015, 10:14 AM
The numbers you made with the LS6 intake are almost identical to what my setup put down. If I weren't determined to go Procharger down the road, I'd go in on a new FAST/MSD/Vararam intake, but I think my money will be better spent on the Procharger setup with stock LS6 intake.
Quick Reply: EPS 234/246 FAST 92/92 PRCls6 9" MADE 448/398
