Weird results...
Old 07-08-2015, 07:14 PM
Nicelysedate's Avatar
Default Weird results...
So I took my car to the dyno for the first time to tune it myself. A local shop with a dynapack dyno (load dyno that's bolts cells directly to hub). First pull did as a baseline yielded 447ft/lbs of torque and 324hp.....
Didn't pay it much mind as tuning wasn't started yet. Unfortunately when I was almost done with my VE tables the load cells overheated. Lost the data on the first pull when it happened.
Those numbers seem terribly skewed and I didn't get a chance to see if the tune fixed it (the cells needed a few hours to cool). What should I look for when I go back? My mods are in signature. I was thinking I would be around 370hp.
Old 07-15-2015, 11:51 AM
blackz97's Avatar
Sounds like you did your pulls with the converter unlocked. When you go back do your pulls with the converter lockup engaged.
Old 07-16-2015, 10:45 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
I have seen varying results from those types of dynos, I wouldn't put any faith in the actual numbers (same for any dyno really), it should simply serve as a tool to see gains/losses, etc.
Take it to the track to see if its making power
Quick Reply: Weird results...
