4.8 Turbo Silverado
4.8 Turbo Silverado
Thought I'd post my results over here too for reference, since I see some people swapping in a few truck engines in their rides.
'06 4.8 Silverado with some heavy 20" wheels. Running a 3:90 gear and trutrac, 60e with 3k stall. KB racing turbo kit with the BW s369 turbo. Custom spec'd turbo can from LJMS. Trunnion upgrade, and cam springs. 80# injectors, Walbro 450 fuel pump.
Have the 9# spring in only seeing about 7#'s with the cam. Made 460rwhp and 442rwtq VERY conservatively.
https://youtu.be/2AmIkTA48AA
Isn't this the same engine they used in this test?
http://www.superchevy.com/how-to/eng...-mouse-part-3/
I just feel like, you are leaving over 250ft lbs of torque on the table at 3k rpm because of the enormous turbocharger.
I'm wondering if maybe you have a leak? Or the exhaust system is really really huge which is killing low flow cylinder VE. Why was there no A/F curve on the dyno? And why is smoothing set to 5? These are signs somebody doesnt want other people to see whats really going on.
Andrew
The turbo is perfect for a 4.8L, and I am sure there is plenty more in this combination. Sounds like an excellent start. Power will only go up as you get a little more aggressive in the tune, if you desire to do so. Good job.
