SLP 402, AFR 205, TSP MS3, Rapid Tuning
Old 11-01-2004, 06:05 PM
max's dad's Avatar
Default SLP 402, AFR 205, TSP MS3, Rapid Tuning
508.7 rwhp, 489 rwt
AFRs were cut .035 for 11.6
Mods include Edelbrock stepped longtubes, ORY, Fast 90 intake and TB, SLP MAF, SLP lid, 4.10 gear, SVO 30#
This thing smokes like crazy. I hope it is unseated rings and that it'll go away, but I'm very concerned.
I'll see if Mikey can post the graph.
Old 11-01-2004, 06:11 PM
ss rally red's Avatar
How much break in before the dyno pulls?
abate1224's Avatar
nice numbers!!
Old 11-01-2004, 06:14 PM
max's dad's Avatar
40 miles give or take a few.
Moderator
thechef's Avatar
what are the cam specs????
Old 11-01-2004, 06:18 PM
H82BBad's Avatar
I think that is pretty good considering it is a fresh engine and I think the heads are a little small for the ci. You should be very happy!
Old 11-01-2004, 06:23 PM
Killer_Bluebird's Avatar
Great Numbers. I'm drawing closer and closer to a combo like that.
Old 11-01-2004, 06:27 PM
If it seals up and stops smoking I might have to rethink the SLP thing LOL.
Old 11-01-2004, 06:30 PM
H82BBad's Avatar
TSP Magic Stick v.3 ("MS3") Camshaft: 237/242, .603"/.6TSP Magic Stick v.3 ("MS3") Camshaft: 237/242, .603"/.609", 113 LSA09", 113 LSA
(He posted that in the other section
Old 11-01-2004, 06:32 PM
max's dad's Avatar
Big if! I could always apply for a Winston sponsorship.
Old 11-01-2004, 06:34 PM
Worm's Avatar
Coooool. Is this the first results of the SLP 402? Not bad for the miles. Keep us posted on the smoking issue.
Old 11-01-2004, 06:45 PM
Moderator
thechef's Avatar
who assembled the motor???? was it assembled by SLP?????
Old 11-01-2004, 07:08 PM
vmax1500's Avatar
Based on some earlier threads, I think he bought the complete shortblock from SLP and had Mike at Rapid install the top end... I could be wrong though... the power is great but the smoking ain't!
Old 11-01-2004, 07:42 PM
max's dad's Avatar
That's correct. SLP claims to build the 402 in house, but I suspect otherwise. Any tips for quick ring seating?
Old 11-01-2004, 07:46 PM
The Guy in MY 99TA's Avatar
Put her in 3rd gear and roll down the highway and go from about start at about 50mph to about 75 and keep going back and forth( or in other words from about 2500 rpm to 4500 or 5000).
Josh S.
Old 11-01-2004, 07:48 PM
Shorty Director
VINCE's Avatar
Smoking is not good, but the #'s are good. What timing are you running and what octane fuel? My car was dyno'd with very little miles on it and it has never smoked. What color is the smoke?
Old 11-01-2004, 08:53 PM
Suspended Sponsor
Race-Prep's Avatar
Hello all,
I would hate to be the bearer of bad news, but if I see ANY more than a little puff right at initial fire up, there is grounds for concern. Every engine that I have seen anyone purchase that smokes more than that hardly ever "seals up", but try to look for any indicators of blowby like exessive pressure in the crankcase and the like and if there is, do a leakdown to check the ring seal, if the leakdown gauge reads more 10% try to get your money back! The thing is once the engine has been dynoed, it is for all common purposes broke in. GOOD LUCK WITH YOUR MISSION.
Old 11-01-2004, 11:03 PM
InsomZ's Avatar
great numbers.. good luck on finding the smoking problems.. its most likely the rings.. on a fresh motor i can't say i'm suprised.. call SLP and see what they say.. see if they'll warranty it if it has bad compression (good luck)
Old 11-01-2004, 11:27 PM
gtodoug's Avatar
Sick numbers, i am dead set on doing this setup for my goat. I hope the smoking stops though. Let us know how it turns out.
Old 11-01-2004, 11:51 PM
LSX Mechanic
Damian's Avatar
40 miles is no where near sufficient break in time IMO. You should have put at least 200-350 miles on the motor before revving it high on the dyno. Nothing has seated in that motor in only 40 miles.
JMO
Quick Reply: SLP 402, AFR 205, TSP MS3, Rapid Tuning
