Dyno related question
Old 11-01-2004, 10:14 PM
JerseyLS1TA's Avatar
Default Dyno related question
I have a 1994 Trans am auto with a 105mph speed limiter. Will the limiter cause any problems on the dyno? I will be getting it done at SLP in Toms River soon but I just wanted to see if this would be a problem. Thanks in advance.
Old 11-01-2004, 10:39 PM
WicketMike's Avatar
i dont think you will be able to get it dyno'd then. becuz it will have to go higher then 105mph on the dyno.
Old 11-01-2004, 10:42 PM
Worm's Avatar
Mine usually goes to like 140 or something so probably.
Old 11-02-2004, 03:19 AM
TNormZ28's Avatar
You will need to remove the limiter through tuning.
Old 11-02-2004, 08:13 AM
dynocar's Avatar
Do the pull in a lower gear that takes you up to 80 - 90 MPH. If they have a Mustang dyno or most other brands, very little difference. A Dynojet will read lower but if you are setting a baseline - so what, just do it the same next time.
EJ
Old 11-02-2004, 03:59 PM
I just want to see where I am at, not expecting to much yet.
Quick Reply: Dyno related question
