What do you think I will dyno tomorrow?
Just wondering if anyone wants to guess? Ill post the graph tomorrow.
I already know what A4's w/ my mods are suppose to dyno but i would like to see how close you guys are.
Mods
2002 rally red A4 Z28
Magnaflow Exhaust/K&N filter/Free Mods/LS6 Block/NGK TR55 Plugs/3.42 Gears/Clear MTI Lid/Porter TB/Aluminum D.S/Smooth Bellow/ M/T ET Streets/ Flowtechs Headers/ FLowtech ORY/HP Tuners/160* Hyperstat/Lower control arms/relocation brackets/TnT Nitrous
Ram Air II Hood/C5 Rims/Nitto 555E Tires
Also I have been told that 18's will make me lose like 10rwhp is this true? I plan to dyno on 16's since thats what i race with but im curious now.
Also I want to dyno the nitrous but dont have a window switch. Last time i dynoed they put it in 3rd and hit the rev limiter.
They should be able to just leave it in 4 right?
Mods
Originally Posted by Blade
335rwhp without the nitrous, maybe a little lower.
330-335 due to the gears as well you may loose some since your not in the powerband as much-i doubt you looks 10 hp form the 18's either mayb 3-4
on an auto it hasta be in 3 cuz thats the 1:1 like the 6 speeds 4th gear is 1:1
you would not believe it. 308/311 and 370 w/ nitrous
This was a tnt wet kit even tho my car dynoed low shouldnt it still put down like 408 unless a lot of fuel was killing it?
Im depressed!
My car runs 12.5 @ 114 and nitrous 11.5 @ 125.5
Is it possible for a car w/ that little hp to run those numbers? Those TRAPS?
The only thing i can think of is that I tuned my car to run in 27-30* weather a while back and it was 80 iat temp when dynoing. At WOT I was adding 9 fuel all the way down.... I checked out the a/f ratio and it was like 960-70s no nitrous....
Could this do it or do I just have a fast number no dynoing car? Car is heavey btw 3650 raceweight...
I am going to start a new thread so i can get some opinions but that the details
Im depressed!
those numbers seem really low to me. how much were you spraying? dont worry too much about the dyno numbers, the 1/4 mile numbers is what matters, and you're doing good there.
Originally Posted by Tiger2o69
100 tnt shot. I mean is it possible for a 308hp car weighing 3650 to run those times?
It was a dynojet..... 60's were 1.95-1.97 n/a and 1.87 nitrous..... Not gtecked downhill lol....
On slicks I run 12.50 @ 111 but it was in hotter weather.
I beat a 500rwhp cobra the other day so the car runs good imo.... I also ran .2 faster at the track than a car that dyno 340 on the same day (n/a).
Nitrous he dynoed 444rwhp i think and mine was 370...
At the track he was spraying thru 1st w/ trapping 90 was...i was spraying thru 2nd only trapping 94-95...
His 60's were slightly better....both around 2.00
This was however after I changed the tune however. Like i said hp tuners was saying i was in the 10/11's a/f ratio but dunno if thats trustable non wideband....
So obviously it must have been the tune in your opinion. There is no doubt about the times. I have slips
Something doesn't add up here. Your all stock internal?? I mean 114 is a very good trap speed for an A4 and what you have listed as mods.Did you dyno these #'s before or after your tune
After I had put a tune in for 30* weather about 3 weeks ago.... The IAT was reading about 80 during the dyno runs...
It was adding 18 on one side of the ltft and 0 on the other .... they were both running high 900's
I think something is wrong as well...
Even if I had a slug motor and say dynoed 300 w/ a tnt 100 shot wouldnt It still pick me up much more than what it did ? 950 psi ....
unless I was running super rich due to the cold weather tune?
After the dyno i went to the track but fixed my tune since it was completely red everywhere on the ltft's..
I know i should have gotten some times before the tune but after it was
running 8.3 @ 87-88
8.0 spraying from 60mph till the end trapping at 94-95
Last time at the track I ran 8.01 @89-90 tho....n/a
running 8.3 @ 87-88
