Finnaly got numbers on the 383!
Finnaly got numbers on the 383! *UPDATED!*
After two months or so of waiting, finnaly got the new set-up on the dyno!
Mods include (also in sig) an Eagle 383 stroker kit (Eagle crank/rods, JE pistons) TSP/Patriot 5.3l stage 3 'race' heads (which I think only flow like 305 or so at .600)
240/244 .608/.612 112lsa cam
TSP lid
ASP Pulley
QTP 1 7/8" headers
all assembled and tuned by myself. After only 20 min or so on the dyno, I put down 478rwhp and 446rwtq! The A/F is pretty close to a 13:0. I can smooth it out quite a bit, and plan on adding a little fuel down low to help with the torque. The torque curve (or line I should say) doesnt really get going until 3,500rpm so....need to work on that a little. I think with a few more tweaks and adjustments, I could see the car get into the 480's. I plan on getting AFR 225 heads and a 90mm intake set-up soon....I'm anxious to see what that does but, for the heads I have, and stock LS6 intake, I don't think thats too shabby. Its a start
I don't have the graph scanned yet, but will try to get one up soon!
-Sean
*Edit, after a few minor adjustments, new numbers as of tonight are 494rwhp/460rwtq! (see pg. 2)
TSP lid
ASP Pulley
QTP 1 7/8" headers
-Sean
12:1 (8.7 DCR) No knock either on 93 pump gas. Total timing was 27* but didnt take much time to test and see what it liked best, but I'm betting about 26-28*
It can be done...My very first pull, I was running just over 14:1 A/F with no knock, but was also running pretty low timing, between 20-22. It was also a cool night weather wise, 64* but...will be intresting to see how she holds up in the summer. Luckily though, she wont be much of a daily driver this year
I am intrested to see what can be gained by opening up the intake. I think that, then the heads, are my big restrictions right now (more so the intake stuff, heads might be ok, for the meantime) I've seen you mention it, but don't think I've heard details on your set up???
SN95 Director
i dont see 500rwhp being a problem with the FAST combo even on your current heads. w/ the AFR's its a given.
basic list of my setup:
Motor:
RMS 347ci LS6 Shortblock
Diamond Pistons 6.6 domes w/ Diamond rings
Eagle #D 6.125 Rods
Stock treated crank
ARP Main Studs
ARP Head Studs
Rollmaster double chain
Ported Ls6 oil pump
comp 850 lifters
FFHP Stg 1 Heads
Ls6 Intake
FTI Cam (240/238 112+0)
Jessel SS Rockers
SLP lid w/ K&N and Smooth Bellows
ASP UD Pulley
Ported TB
160 T-Stat
Exhaust:
Jet Hot LT's
True duals
Fuel:
SVO 30#'ers
255 L/hr Fuel Pump
Tranny:
Pro 5.0 w/ LSS and Hurst ****, !CAGS
Spec 3 clutch
Hays Aluminum Flywheel
Mac Girdle w/ studs
Suspension:
Pro Fab K-member
Poly motor mounts
BMR STB
Motor:
Eagle #D 6.125 Rods
Stock treated crank
ARP Main Studs
ARP Head Studs
Ported Ls6 oil pump
comp 850 lifters
FFHP Stg 1 Heads
Ls6 Intake
Jessel SS Rockers
ASP UD Pulley
Ported TB
160 T-Stat
Exhaust:
Jet Hot LT's
True duals
Fuel:
SVO 30#'ers
255 L/hr Fuel Pump
Tranny:
Spec 3 clutch
Mac Girdle w/ studs
Suspension:
Pro Fab K-member
Poly motor mounts
BMR STB
Awesome numbers with those heads...they are your restriction after the intake..not sure if you will make 500rwhp without getting rid of them
Your car made almost identical numbers to mine...im a little less compression and lift but with 90mm.
Motor:
Eagle #D 6.125 Rods
Stock treated crank
ARP Main Studs
ARP Head Studs
Ported Ls6 oil pump
comp 850 lifters
FFHP Stg 1 Heads
Ls6 Intake
Jessel SS Rockers
ASP UD Pulley
Ported TB
160 T-Stat
Exhaust:
Jet Hot LT's
True duals
Fuel:
SVO 30#'ers
255 L/hr Fuel Pump
Tranny:
Spec 3 clutch
Mac Girdle w/ studs
Suspension:
Pro Fab K-member
Poly motor mounts
BMR STB
Motor:
Eagle #D 6.125 Rods
Stock treated crank
ARP Main Studs
ARP Head Studs
Ported Ls6 oil pump
comp 850 lifters
FFHP Stg 1 Heads
Ls6 Intake
Jessel SS Rockers
ASP UD Pulley
Ported TB
160 T-Stat
Exhaust:
Jet Hot LT's
True duals
Fuel:
SVO 30#'ers
255 L/hr Fuel Pump
Tranny:
Spec 3 clutch
Mac Girdle w/ studs
Suspension:
Pro Fab K-member
Poly motor mounts
BMR STB
thats an interesting head and cam choice...cant wait to see it...
Thanks! I'm still undecided where I want to go from here. I'm kinda thinking about a new cam....I usually swap those out once every month or two anyway :p but I think the intake is definatley pretty close to next on my list. I figure thats probably my biggest restriction. I'm running a MAFless tune so I can ditch the MAF, try to find something to do for a smooth bellow to replace it, a 90mm intake and TB
Originally Posted by Beast96Z
This gives me great hope for my 500RWHP goal from my 383.
Sean
