Anyone dyno a T-rex or similar with AFR's yet?
King of Pigskin Knowledge
I know the T-rex was made for stockers, but I'm just curious if anyone has dyno'd one with AFR's? Or even a cam similar in size? Thanks.
Brandon
Originally Posted by jrp
Fireball had AS heads, i think. He put down 454rwhp w/ some issues. im not sure if he re-dyno'd after changing the ICL.
Brandon
SN95 Director
Originally Posted by xfactor_pitbulls
I know that there have been several guys on this board and others that have hit 440+whp cam only. One would hope that any good stage 2 heads should yield 460+ right?
Brandon
Brandon
heres the thread, there GTP heads, not AS.
https://ls1tech.com/forums/dynamometer-results-comparisons/226154-dynoed-trex-gtp-combo-peaked-awefully-early.html
Originally Posted by onesweetz06
I dyno'ed 478 RWHP with a TRex on a stock bottom end 346 LS6 Z06 with stg 3 6.0L heads.. This was done through the mufflers on pump gas in florida heat with no dyno tricks.
AFR 205 Heads, Custom Comp Grid Cam 245/249, 569/569, 111lsa, ASP Under Drive Pulley
Pacesetter LT and TSP duals made 453rwhp and 410rwtq ... I know this guy
http://www.hendersonvilletinting.com/files//7685674.jpg
Originally Posted by Louis
Sorry, Im off on the Tq. That was the older AS LS6 heads that had 450 tq.
http://lgmotorsports.com/viewimage.php?id=101
