My car is a SLUG low dyno #'s
Went to a new shop that was doing dyno nights for $35 so it's been 2 yrs since I last dyno'd and haven't dyno'd since my cam went in last last Jan.
First off we're watching them dyno sticks in 3rd gear..........WTF? I told the guy do both of mine in 4th. So he goes to do it and what does he do he goes from 3rd to 2nd then nails it retard didn't go to forth
.........wow that was fast atleast my car will look good when I do spray it someday But the car looked cool when the nose shot up. 299 RWHP on a 2nd gear run Did you know we show more power with a 3rd gear pull so he said
I dropped 316 RWHP bone stock, 327 stock with an air lid, 338/340 with Headers, and an ORY.
I go tonight in 70 degrees to run a whopping 344 RWHP 348 RWTQ with a cam!!
Hahaha, this place is WAY off, considering my car runs low 12's and has also gone 11.91-11.92 before and trapped 116 @ 117 in good air.
Thought you'd all get a kick out of a small cam LS1 that gained 6 RWHP from a Comp cam.
I will be going to my regular dyno in a few weeks to get some REAL numbers and get back to you.
He had no clue of what he was doing. I was sitting there watching him do a Mustang and pull it in 3rd gear. I was like, that's not right. I told those peope do both of mine in 4th gear.
I told the guy to run 4th I have a shift light set at either 6400 or 6600 (can't remember) and the rev limiter set to 7K so he would be fine to run it to the shiftlight and stay in it. Dave told him to peg the rev limiter so we can see where the cam is pulling to because I may be able to shift higher.
Anyway, long story short he never pulled my car past 6500 and I never saw the shift light come on on his face. I think the sound of the cars scared these people. Mine was nasty loud once it's WOT.
So that was it, the graph they had has no air fuel, and it's not a normal looking graph I am used to seeing the graph showing the curves on it with the grid.
I am going to go back to the dyno I've used since 2000, same shop, same dyno........that's it and SAME Person driving my **** (he builds all out race cars he can drive )
How bout that Vince Wanna take a ride in my magical car? It's a sleeper. BTW, Gator, I heard Jeremy is coming down to tune some Fbods here.........I will go up there for him to tune me so I can meet up with some Tampa people and stick some break in miles on my motor.
Originally Posted by GREATWHITE
what kind of dyno was he using? Eddy-current dyno's don't require that a 1-1 ratio be used. It will read the same power in any gear.
EJ
Same thing happend to me once. I dynoed at a local import show last summer, a dyno that came right off the back of a truck. Anyways I put down 260rwhp.........then a civic with just an intake and muffler hopped on and dynoes 350rwhp........it was funny. They were behind 1 for every car.
Originally Posted by Wild85
YOu have to dyno a car at as close to a 1:1 ration as possible, 2nd gear will give you more power, than 3rd or 4th
Originally Posted by 97bowtie
It's the other way around. Dynoing in 2nd will give less power than dynoing in 4th gear.
EJ
Originally Posted by dynocar
I agree with an inertia dyno but on a load dyno the #s could be very close if the acceleration rate of the engine is programmed to be the same and if traction does not become an issue. We can not and sometimes refuse to do 4th gr pulls on some cars due to MPH speed goveners and tire speed ratings. I've seen enough fan belts, blower belts, hot oil, drive shafts etc come flying across the dyno shop, don't need tire caps too. This is why we do not promote car clubs and audiences. (Organizers of such activities could be liable).
EJ
EJ
That's okay, I was wondering what my power was with a cam. But I have the track #'s to say the dyno isn't accurate.
I will post back other #'s when I hit the same one I've used for the last 4 yrs.
Originally Posted by Mike98WS6
It sounds like this guy dyno's lawnmowers for a living.
Here is what 2 Friends that were there saw:
I also saw "Bill" take a pair of dikes and a razor blade into your engine compartment. I thought that maybe he was clipping a zip tie or something to get to your tach signal wire. Now that we know that something else was clipped (i'm sure it was an accident)
Now that you said this, last night they clipped some wire or something when they put your car on the dyno. Right when they were hooking it up to the tach output I believe. I dont think if this even makes a difference, but they cut something and im not the only one who saw it.
Originally Posted by racer88
Well since being there my ABS Inop is lit, they have cut a wire somewhere.
A common problem on ABS F Body cars dynoed by new dyno operators is that they wrap the left rear axle strap around the axle and the ABS harness. This pulls the harness' plug loose or damages the harness when the strap gets tight.
EJ
EJ
EJ
Well the car is now fixed and yes, you are right about that.
EJ
My Boyfriend figured right away what they probably did. The confusing thing is the bystanders that thought they saw they 'cut' something in the engine bay. We have no idea but wires etc have also been checked and appear to be fine.
I won't be going back to that dyno ever again. I will go back to the one I've used in the last few years. I've never had an issue ever at his dyno and he's got some serious race cars he's built dyno at his shop...........if he can secure them down safely there is no reason he can't get a 360 RWHP car secured
FWIW, I raced my car Friday night with no ABS and to tell you the truth our cars are fine without it........not that you use ABS on the track but our cars with good brakes and good rotors stop so well anyway, thing is I don't wanna know what it feels like to try and stop on my skinnies
