fm11 & g5x1 dynographs please
Old 02-18-2005, 07:18 PM
bad0211secws6's Avatar
Default fm11 & g5x1 dynographs please
trying to decide on fm11 or g5x1 they seem pretty close id just like to compare the torque curves of these cams thanks for any comments or graphs
Old 02-19-2005, 09:05 AM
wow guess these arent very popular cams maybe i should try an slp cam
Old 02-19-2005, 09:21 AM
well i bought the g5x1
still would like to see some torques curves i know someone here has one. (preferably with stock heads)seems like i seen a comparison from someone which compared 3 different cams but i cant find it with the search.
also i know these specs are not ideal for nitrous BUT what are the drawbacks
125 wetshot on g5x1 228/232 .588/574 112 how is the nitrous going to affect the
more air in and less air out? p.s wifes gonna be pissed told her cam would idle like stock ohshit (keep me in your prayers)
Old 02-19-2005, 03:20 PM
black_z's Avatar
Be sure to post up the graph when you get it tuned.
Old 02-19-2005, 03:23 PM
ablakez28's Avatar
let me know how you like it. and dont you worry about the tq
Old 02-19-2005, 03:25 PM
should be goin in next week so ill have it tuned after that and ill post em soon as i get em
Old 02-20-2005, 02:18 AM
01_SuperSlow's Avatar
Here ya go
Old 02-20-2005, 08:19 AM
Black02SS's Avatar
IMO this graph isn't a good comparison. The AFR for all three cams is different. If the car was tuned to the same AFR, then it would be a better comparison.
Old 02-20-2005, 08:59 AM
Originally Posted by 01_SuperSlow
Here ya go
thanks a lot what cam is the green one
Old 02-20-2005, 11:06 AM
LSUxBlake's Avatar
I Believe the green one is a TR224
Old 02-20-2005, 12:51 PM
wow thats pretty good its not far behind the big cams
Old 02-20-2005, 05:46 PM
98TAauto's Avatar
good info..... look like ill loose a tad of low end, but gain about 15hp uptop.. i went from the 224 to the F11
good in a way since shift extension is 5400-6500
Old 02-20-2005, 06:20 PM
f11 sounds very good i installed one for rollinsscamaro
Old 02-20-2005, 06:41 PM
SStolen's Avatar
I have the G5X1 in my car. That graph sounds about right. This cam gives up a little on the low end but really picks up on top. I would def. recommend gears.
Good luck on the tune. I never realized the full potential of the cam b/c I never had it tuned and am pulling it out for a turbo kit in the next few days. Without a tune, it idled like ****. Cold starts are a bitch and until you idle for a couple minutes and make a few stops I had to give it gas to keep it from dying. Once it found an idle it sounded badass though!
Old 02-20-2005, 06:53 PM
black_knight's Avatar
You people need to pay more attention. That graph is a G5X2, not a G5X1.
Old 02-20-2005, 07:02 PM
Black02SS's Avatar
They don't care, all they are doing is looking at the numbers and not taking into account that it isn't a true comparison. The car needs to be tuned for each cam, then you can make a GOOD ACCURATE comparo.
Old 02-20-2005, 07:29 PM
98TAauto's Avatar
true that.. looks like the 224 cam had the best A/F of all 3.. the other 2 cams looked a little to lean mor my tastes.. i'd like to see them all with the same rough A/F
Old 02-20-2005, 07:31 PM
True dat.
Old 02-20-2005, 08:10 PM
jrp
SN95 Director
jrp's Avatar
chad, i believe the thread starter of the graph said all 3 cams were tuned.
Old 02-20-2005, 09:39 PM
I think the guy that posted that graph (it's not my graph, I just have it saved in my computer) said that the f13 run was experiencing valve float.
