Preliminary TTP Stage 3 Equalizer H/C Package Results Within --
2002 Z06
TTP Stage 3 AFR 225cc heads (2.08int/1.60exh) (Finish Polished/Ported by TTP)
TTP Equalizer V.3 Camshaft
10.3:1 C/R
Stock Bottom End
LSX 90mm Intake
NW 90mm T/B
Mez Electric Water Pump
ASP U/D Pulley -- Full Belts
TPIS LTs with CATS (Hurting the car greatly)
19" IForged Rims
Here is the graph from last night. We're closed early today because of another snow storm we're supposed to get hit with. Look for more #s tomorrow:
*Note: The tq spiked when we lost signal. The actual peak tq is 421.36.
These results are done at 24 deg timing. So we'll be putting in max timing tomorrow and see what she does.
10.3:1 C/R
Stock Bottom End
LSX 90mm Intake
NW 90mm T/B
19" IForged Rims
GrannySS: I'll post the graph tomorrow. It is making over 480 from 6k or so. I dont remember off hand but its making awesome power after the curve and good torque down low. Since I only got a few runs the torque curve was kind of low but it definitely has more in it.
- Matt
- Matt
stone4779: The specs that you have listed are too high. The cam is in the range of a G5X, TSP magic stick cams... It's not a 240+ duration. And that's all I'll say
These results are done at 24 deg timing. We adjusted the A/F to about where we want it. So we'll be putting in max timing tomorrow and see what she does.
