PRC Stage 2.5 & TSP Mini Stick Before & After Results!!
After some testing with the new PRC heads & the prototype Mini Stick camshaft I decided it was time to post a preview of the setup
The car currently has:
01 car
241 stock heads
LS6 Intake
Texas Speed Mini Stick Camshaft
235/240 .603/.609 113 *Camshaft in testing to clear with PRC heads
Hooker Headers
True Duals
ASP Under Drive Pulley
80mm Throttle Body
That's about all I can remember
After the dyno we installed the PRC 5.3L Stage 2.5 heads with stock head gaskets & NO VALVE RELIEFS!!!
Here's the specs on the heads:
Precision Race Components 5.3l Stage 2.5 Heads
Brand New GM Castings (manufactured & finished by GM)
Manley LS1 Valves
2.04"/1.575"
PRC Gold Double Springs Rated to .660" Lift
Titanium PRC Retainers (specially built for prc by Terry @ Racetech with his new cnc lathe)
Everything on the heads are brand new & built to tight tolerances to insure every set is right way before they're ready for shipping.
01 car
241 stock heads
LS6 Intake
Hooker Headers
True Duals
80mm Throttle Body
Manley LS1 Valves
2.04"/1.575"
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
We have a few additional ones on order. We also still have a few of the early versions on a tighter lob sep available in the for sale section for under $300. This camshaft should be ready to go the middle of next week...
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Great numbers
I got the 233/239 cam from TSP and hope to postnumbers with the rest of the parts in my sig when I get them installed in the next two weeks, I hope I make good power to.
Auctane_71,
Keep us posted on how it works!!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
That was my question. I am guessing it is an auto car with a large converter. If so that would put this car in the 490's with a 90/90 set up and a M6. Throw on some QTP's and maby even more. It looks like a great combo.
i sould also like to know why causes that spike...does anyone know?
it says on the graph "spec stage 3 clutch", so i assume that it is an M6.
thanks, this setup looks interesting...
Louie
Louie
Sorry for the delay on getting back guys! I'm not sure on the dip on this one..
The car has a 3.73 gear 10 bolt
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
