How much HP loss with this drivetrain - plz hlp
Okay. I want to make a set of custom emblems for my hood, but I am wanting to have an accurate # on there.
I have a stock T-56 with a Spec 3 clutch, aluminum driveshaft, stock 10-bolt with 3.73 gears, and 17" Z06 motorsport wheels.
I made 522RWHP with a 78MM intake, and no tuning. I have added a 90MM intake setup, and will tune next time. I am hoping for 550RWHP. I want to put flywheel HP numbers on the hood, so I need to calculate loss. Does anyone know what percentage HP drain that these drivetrain components have?
Thanks guys.
Thanks guys.
I know a lot of Ford people use a 19% drivetrain loss number with a T-5 and a Ford 8.8". The T-56 takes a little more. I have no idea about Chevy rears. Why not call it 20% loss (divide RWHP by 0.8 or multiply by 1.25 to get FWHP). It's conservative and probably accurate. 653 for your dynoed setup, 688 for what you are hoping to get.
Mike
Mike
I normally use 17% for M6 but that pretty much a guess. Autos have a whole lot of variables in converters so its even more of a WAG. I think if you search around you will find something very close to 17%
Super Hulk Smash
Between 50-60HP.
It's not a percentage, it's an actual number. Dyno it on a engine dyno to see.
The reason? Why would it suddenly take MORE HP to drive the same components? If you replace the stock LS1 with a 408 making, oh, 522rwhp, the percentage difference at 15% is 51hp vs 92hp. Why did it suddenly eat 41hp more to drive the same rearend and transmission? It didn't. A 522rwhp engine is around 575 at the flywheel. 550rwhp is 600HP.
Originally Posted by JakeFusion
Between 50-60HP.
I like your point, though. That is the best input I have heard yet.
Still dont believe me? I can easily turn the drivetrain over by hand, and I can assure you that my hand is not producing 50 - 60 HP.
If it is a "fixed" amount, then expain this, on everything from a stock low HP VW to a stock high HP Viper, when we use our standard percentage multipliers for different drivetrains, such as manual Vs auto, we have always come very close to the advertised factory net SAE flywheel rating. This is based on 15 yrs of full time chassis dyno experiance on two different brands of measurable load dynos (Clayton and Mustang).
Between 50-60HP.
There are a number of real, physical reasons why it ain't, but let's just say that a drivetrain's efficiency is DEFINED as Power Out divided by Power In times 100% and the efficiency percentage for a given setup doesn't change all the way up to the physical limits of the drivetrain! Not an opinion, just the facts.
On topic: a stock converter A4 is about 17-18% loss (crank hp times .83 for whp) and the M6 is a little better (no converter loss) at about 14-15%. An aftermarket, higher stall converter goes about x80%x (oops, should have said 20% - chp x .80 for whp) for the A4. HTH
Originally Posted by TOSTO RACING
I've done both with the same motor rwhp flwhp and 15% was dead on actually on this application it was 518 rwhp and 613 flywheel. So figure 15% and you'll be fine .
Originally Posted by GuitsBoy
Because the 408ci is going to accelerate the rotational mass inside the drivetrain much more quickly than the stock motor will, which requires more power to do so. This is the basic idea a dyno works off of. Accelerating the drivetrain more quickly puts more pressure on the gears, which creates more friction, which also takes power to overcome. This is why it is indeed a percentage and not a constant.
But could you spin it over at 500rpm or 5000rpm? And that's really what HP is all about. As you don't measure HP you derive it from torque at a particular speed.
Sure there must be more loss at 5000rpm than there is at 500rpm because an engine at idle can still move a car along a level gradient even if it isn't producing much power. But 5000rpm with 300bhp or 500bhp I can't see it making any odds as the rpm is the same as is the rotating mass.
I am a strong beleiver that HP is not a fixed percentage loss, but I also don't think it can be 100% static loss either. A fixed amount plus a deminishing percentage is the only answer I have been able to come up with.
I think it is for this reason too many people always think their engine produces more power than they think. But there's no way a 520rwhp car is making ~650bhp at the engine.
Example's being (using a Mustang Dyno as it is load bearing and correcting to SAE):
A 260bhp Mustang will tend to dyno ~220rwhp HP so we can see a loss of about 40bhp
A 345bhp Corvette or Fbody will tend to dyno ~295bhp so a loss of 45-50bhp
C5 Z06 405bhp and ~350rwhp again ~50bhp loss
C6 Z06 512bhp with ~450-460rwhp giving 50-60bhp loss
So if a car genuinly dyno's 550rwhp (Mustang Dyno) then it would be logical to assume 60-70bhp loss at the most this would give you a real world figure of 620-650bhp SAE Net The 15% rule is not far off and the 12% + 10bhp rule also coinsides.
But it's better to be more conservative than over the top so if you claimed 620bhp SAE Net then you could be pretty certain no matter the weather or altitude it is probably going to be making that number as a minimum.
Of course none of this has taken into account varaiton in dyno type, correction factors, standards and graph smoothing.
LS1 Tech Administrator
It is closer to a fixed number than it is a percentage. Like JakeFusion said, with your particular setup, it's probably close to 50-60 rwhp. You think your motor is going to be at 550 rwhp (possibly optimistic). Keeping that in mind, a badge that says 600 hp would be perfectly appropriate. But a 15% loss on a 550 rwhp engine is 97 hp. I think that's a little on the high side. 60 hp loss at your power level is probably more like it. If you think 600 hp looks too common, then give it an oddball number like 605 or 610.
Just don't put your ***** size on your car too, the hp emblem is probably enough bragging, LOL.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
so 400rwhp would = what if the car was a automatic and stalled
also does a locked up converter car have about the same efficnecy as a manual?
i was looking at my number this way 500bph x .85 (15% drivetrain loss in a m6) = 425-20 (unlocked ssf 3500) =405rwhp is this correct?
the car has 17x 11 wheels and a steel driveshaft bulit 10bolt 3.73 rear gears
Super Hulk Smash
Maybe my example was not the greatest. So let's assume a stock LS1 vs a typical head/cam LS1. Same rotating assembly, same weight of pistons/rods/crank. Lighter clutch assembly on the head/cam engine.
300rwhp vs 450rwhp at similar RPM (which is possible). 15% rule means, 352BHP and 529BHP--differences of 52 and 79. The engine didn't get heavier at the same RPM, nor did it suddenly start making more friction. If anything, the new clutch assembly is helping it make more power on the dyno, meaning it is now eating less engine brake power. So, is it 500BHP or 530BHP? I don't really care, but I'll say it's closer to 500.
look at it this way, the equation would look more like this: y = 1.01x + 40 rather then y = 1.25x. this yeilds the idea of diminishing return per horsepower. y= engine horsepower, x= rwhp. with a constant horsepower (exaple:40) derived from the weight and centripital forces associated with the rotational masses.
