How much HP loss with this drivetrain?
Old 03-06-2006, 11:49 PM
dragonZ28's Avatar
Question How much HP loss with this drivetrain?
I posted this in another forum, but didn't get a response.
Okay. I want to make a set of custom emblems for my hood, but I am wanting to have an accurate # on there.
I have a stock T-56 with a Spec 3 clutch, aluminum driveshaft, stock 10-bolt with 3.73 gears, and 17" Z06 motorsport wheels.
I made 522RWHP with a 78MM intake, and no tuning. I have added a 90MM intake setup, and will tune next time. I am hoping for 550RWHP. I want to put flywheel HP numbers on the hood, so I need to calculate loss. Does anyone know what percentage HP drain that these drivetrain components have?
Thanks guys.
Old 03-07-2006, 12:24 AM
ArcticZ28's Avatar
off topic - what's the cost and flow numbers on those heads?
on topic - why are you wanting to advertise flywheel hp?
Old 03-07-2006, 01:34 AM
dragonZ28's Avatar
TEA flowed them as follows:
.1000-----68.3-----55.3
.2000----143.3----124.7
.3000----225.3----178.4
.4000----270.4----233.8
.5000----307.3----259.6
.5500----319.2----266.1
.6000----324.2----270.0
.7000----330.0
Total price shipped:
$2135.65
These heads are an extremely good value. They are top-shelf! TEA is one of the best cylinder head companies in the world, and their work reflects their reputation.
I am advertising flywheel HP because that is the indutry standard, and that is the only way to make a real comparison to other vehicles on the road. Also, since it's on the hood, I want to show what kind of power is under the hood.
Old 03-07-2006, 08:18 AM
ArcticZ28's Avatar
Not bad for the price on those heads! I gotcha on the flywheel hp now. As for the drivetrain loss, I'm not sure on the actual numbers but I would figure it would be a bit more than the ~15% stock drivetrain loss seeing as you have a lightened DS but steeper gears and probably a bit heavier wheels.
Old 03-07-2006, 10:17 AM
BLWN1's Avatar
put it on an engine dyno....or quit being mentally challenged.....
Old 03-07-2006, 03:23 PM
white2001s10's Avatar
Just write on the hood that you're losing 60hp to drivetrain loss.
The rycers will understand.
Old 03-07-2006, 04:34 PM
SoCalZ28's Avatar
i thought it was typically 18-23% something like that. correct me if im worng
Old 03-07-2006, 04:45 PM
scamp2279's Avatar
I have always gone on the figure of 20%
