TTP Custom STS Turbo w/ FMIC, A4
Old 03-09-2006, 01:09 PM
TTPMatt's Avatar
Default TTP Custom STS Turbo w/ FMIC, A4
This is the STS rear-mount turbo system with a GT-67 and custom front mount intercooler. Here are the details:
2001 Camaro SS
TTP Built Stage 3 4L60E
Vig 3200 Converter
Stock LS1 Heads
Stock Bottom End
TTP Equalizer V.3 Camshaft
Crane Dual Springs, Titanium Retainers
SLP 1 3/4" LTs with Cats
STS Turbo, GT-67 - 10PSI
TTP FMIC Setup (OBX Intercooler)
3" into I/C, 4" stepped out to SLP 85mm MAF, NW 90mm TB
FAST 90mm Intake
TTP Custom Standalone Fuel System utilizing stock plastic gas tank, A/M A1000 pump, A/M fuel rails
Note: Still have some A/F changes to make, currently the car is down, hurt #7 cylinder.
Old 03-09-2006, 07:18 PM
DocEwww's Avatar
Thats the SOM SS right? That car is BADASS....very impressive #'s.
Old 03-09-2006, 07:32 PM
bad95killer's Avatar
Awesome #'s man & sorry for the Cylinder
peace
Old 03-14-2006, 12:39 AM
socalstreetracer's Avatar
why is it so laggy? I make full power by about 4700 with a 100% stock 99z28 with cats. How much timing were you running?
Old 03-14-2006, 11:01 AM
TTPMatt's Avatar
These are the initial runs. Motor is now hurt so we will be replacing it for a low-comp setup soon.
And yes, this is the SOM SS.
Old 03-14-2006, 08:24 PM
good luck!
Old 03-14-2006, 08:44 PM
blkbird's Avatar
Awesome #'s. Good luck with the cylinder fix.
Old 03-14-2006, 11:23 PM
FACE's Avatar
10PSI!? No wonder the car is hurt.
Old 03-15-2006, 07:13 AM
TTPMatt's Avatar
Customer chose to run the boost this high. It was a beast for a while. He expected to be doing the bottom end sooner or later.
Old 03-15-2006, 07:52 AM
offaxis's Avatar
That thing is gonna be crazy on 15-20 #`s and the new shortblock
Old 03-15-2006, 08:15 AM
cablebandit's Avatar
if thats on a dynojet, you cant call it laggy. my incons look like they dont build boost till 4000 rpms because of the low loading of most dynojets...even though on the street they start at 2500 and full boost by 3400.
Old 03-20-2006, 10:34 AM
TTPMatt's Avatar
cable is correct. The dynojet only puts 2400lbs of load on the vehicle.
Old 03-22-2006, 10:27 AM
RealQuick's Avatar
Nice Matt... a little laggy, but we'll see what happens when you get it fixed and dialed in.
Old 03-22-2006, 11:25 AM
Silver-Dollar's Avatar
The last picture looks like either blessing it or giving last rights
Old 03-22-2006, 04:18 PM
TTPMatt's Avatar
lol Silver-Dollar. We will call it a blessing, too bad our prayers weren't answered. 10PSI is way too serious for a stock bottom end but it was not my choice. I would personally run 6-8 tops. Plus remember this motor has seen nitrous before and it driven very "spiritly"
Old 03-22-2006, 10:34 PM
pdanrichey's Avatar
Stock internals/stock heads should take 8psi with the FMIC right? With a good tune, you should be making about 500rwhp correct? I was thinking the same thing...the hp curve seemed...weird? Typically you'll see a "large" jump around 3500-4000rpms.
Old 03-24-2006, 02:01 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
why was it ran so lean?12:1 is WAY to lean for a stock motor with FI
Old 03-24-2006, 04:08 PM
TTPMatt's Avatar
We are changing the cam setup for this motor. Little too aggressive and not the turbo cam I would use so we are changing it.
Old 03-24-2006, 05:07 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Not really, I pushed 11 psi for a while. Down to 9 psi now.
By the way, nice numbers
Old 03-29-2006, 09:26 PM
qwikz28's Avatar
thats RJs car!
Quick Reply: TTP Custom STS Turbo w/ FMIC, A4
