Thunder 230/224 575/563 111 LSA cam results.
Old 03-29-2006, 10:17 AM
ROJO99's Avatar
Default Thunder 230/224 575/563 111 LSA cam results.
Finally visited the Dyno with the new cam in place. I hit the numbers I openly admitted to, but really wanted about 10 more.
HP=370 TQ=359 AF was around 13.0.
The cam idles well at 850 RPM with a mild Lope and is really tame thru LT's and stock mufflers. With dual valve springs I have the rev limiter set to 6700 and the cam pulled all the way to 6600.
I was really shocked to see the TQ curve. Flat from idle to 3000 the raises to peak by 3800 then flattens back out. I guess this is a result of the 111 LSA.
I am wondering if my stock mufflers are holding any power?
Old 03-29-2006, 10:24 AM
TXZ28LS1's Avatar
you should be making atleast 380-390 on stock heads if anything.. im pretty sure that stock exhaust is eating up power for sure. what other mods do you have?
Old 03-29-2006, 10:31 AM
Sport Side's Avatar
What are all of your mods?
Old 03-29-2006, 10:40 AM
bad95killer's Avatar
peace
Old 03-29-2006, 11:13 AM
ROJO99's Avatar
Mods and car are:
99FRC, Torch Red, B&M Ripper, Raptor Shift Light, Varam Air filter. Dyno = 317.8HP@325.4Torque.
Above Mods plus an LS6 intake
Dyno = 323HP@329Torque.
Melrose LT Headers, Random Cats and X-pipe
Dyno
Thunder 230/224 575/563 111LSA cam eith Patriot dual springs.
Best Run, 12.20@113.6 with BFG DR's (Pre Cam)
Old 03-29-2006, 12:45 PM
Zick's Avatar
Got a graph?
Old 03-29-2006, 04:29 PM
Worm's Avatar
Get some Stingers, stock C5 mufflers suck unless they're the z06 ones. I'd say you're leaving 10-15rwhp on the table with the stock catback. My '99 picked up 9rwhp on a stock motor.
Old 03-29-2006, 05:19 PM
black_z's Avatar
Cats and mufflers are killing your power. Im betting you would be around 390 with cutouts and no cats.
Old 03-29-2006, 06:18 PM
ROJO99's Avatar
Graph from dyno.
Attached Thumbnails Thunder 230/224 575/563 111 LSA cam results.-dyno2.jpg
Old 03-30-2006, 11:19 AM
Worm's Avatar
Is the redline 12:1 or 13:1. either way looks pretty lean in the lower RPM 15:1 range? Or am i reading it wrong, hard to see the numbers on the right. Man people always manage to take the WORST pics on the planet and then post them. LOL
Old 03-30-2006, 11:33 AM
Allergik2dyin's Avatar
Old 03-30-2006, 12:02 PM
ROJO99's Avatar
SDC, The RedLine fuel air was 12.9. A little lean, but the measurements where taken fron the tail pipe so I question the readings some.
Old 12-28-2006, 08:26 AM
casado's Avatar
That's the one that I'm planning on getting...I have LT's, ORY, LM, 80mm BBK TB, K&N FIPK, Ported MAF And I will get my heads ported (Because Is More a DD,Not too much track) and In a few months I'm going to spray some TNT (Work My way up to 150 shot) What yall think abouth my plans? any sugestions? tips? any HP guesstimation on this setup?
Thanks Guys!
Old 12-28-2006, 08:55 AM
LS1Tech Sponsor
Slowhawk's Avatar
Looks good to me for the mods you have. The Cats,exhaust are hurting and I don't see an underdrive pulley.
Old 12-28-2006, 10:55 AM
ROJO99's Avatar
Casado, I do not see any reason this cam with good tuning can not put down 400RWHP on stock heads.
Old 12-28-2006, 08:45 PM
john563's Avatar
talk to or pm gillbot on here.He is in huber heights and has that cam stalled A4 399.2 rwhp and talk to 98redorangeta (he is in Vandalia) on here he did the tuning on gillbots car maybe they can help you out.When I was not happy with my numbers/drivability gillbot introduced me to marc(98redorangeta) and he tuned my car.Ill send you a pm
Old 12-28-2006, 09:16 PM
gillbot's Avatar
Holy old thread batman!
You should be closer to 390 imho. Get that exhaust off there and toss on a UD pulley, you should get close to 400.
Old 12-29-2006, 10:08 AM
30th t/a's Avatar
remember, vettes are known to dyno 5-8rwhp lower than fbodys. I read that the rearend sucks up more power than fbody's & 10 bolt. get a good exhaust & U/D pulley and you'll be right were you should be.
Old 12-29-2006, 09:24 PM
casado's Avatar
Good! That's where I'm sooting for!
Old 12-29-2006, 11:20 PM
JRracing's Avatar
I had this cam 2 years ago. It made 390rwhp with open cut out and 384 with it closed. Look at times in sig. Full weight on skinnys and et streets. It was only the thrind time I sprayed it with the 150 shot. On a N/A tune. Hmmm makes me wonder what it really would have done.
