382ci & 402ci H/C post your numbers.
Old 04-10-2006, 03:44 PM
prostock_bigblock's Avatar
Default 382ci & 402ci H/C post your numbers.
Hi all,
I am between these 2 choices so far but I need to see some numbers from both combos.
post both N/A and the bottle.
M6 numbers r preffered
Thanks.
Old 04-11-2006, 01:25 PM
383ss's Avatar
I had an M6 383 stroker with a 236/232 cam, 11:1, nice heads and all the bolt'ons. it put down 490rwhp on pumpgas.
Old 04-11-2006, 02:13 PM
nice numbers with that mild cam.
tttttttttttttt
Old 04-11-2006, 02:16 PM
I am sure plenty of u guys out there.
Old 04-11-2006, 05:47 PM
Chuck Harmon's Avatar
SLP 402, AFR 225 65cc heads; 228/230 @ .591" Comp Cam; Factory air box, TB, & Intake. Great tune by Rick @ Synergy!
Chuck
Old 04-12-2006, 09:47 AM
David Gordon's Avatar
Mines not a 383 but for the same money you can have a 395". from what I have seen the 395" make a little more torque than the 382". Mine made 470 rwtq. and 489 rwhp.
Old 04-12-2006, 11:13 AM
guys what is the biggest stroker I can go with stock crank and stock block? I am trying to benefit from every dollar in this setup.
ttttttttttttttttttttt
Old 04-12-2006, 11:17 AM
LookinAtMyPlate's Avatar
Id like to know the same!
Old 04-12-2006, 11:56 AM
395 is the Biggest you can get with a LS1 block without resleeving. I have had mine for a couple years and going good. Texas Speed built mine and did a very nice job. You can resleeve the LS1 block but it is costly.
I missread your post you cannot have a stroker and a stock crank. I think they can regrind the crank and you would have an offset grind stroker but I wouldnt want one.
Old 04-12-2006, 12:39 PM
cant u get to a 370ci or 374ci with stock crank? or I guess this is on the 6.0 block?
Old 04-12-2006, 12:42 PM
I well be looking for a 12:1 compression for this setup.
Old 04-12-2006, 12:47 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
bigest you can fit is a 4.125 crank with the right clearancing....3.9X3.9X4.125X8X.7854=~395
Old 04-12-2006, 12:50 PM
395 is what I have and I love it. I have no regretes with this set-up. With 12.1 comp. you will have to run race gas sll the time. I have 11.1 and that is perfect.
Old 04-12-2006, 04:08 PM
Ksett's Avatar
I think this depends on the characterisics of the cam which will ultimately affect dynamic compression. So you can run 12:1 static compression with a properly matched cam running pump gas.
Old 04-12-2006, 04:36 PM
beardWS6's Avatar
408 Baby!!!
Old 04-12-2006, 09:23 PM
slow trap's Avatar
the 6.0 has a 4 " bore verses the 3.898 but they have the same stroke,the bore is where the extra cubes come from.
Old 04-17-2006, 11:46 PM
Blown04Z06's Avatar
just spend the extra $1000 on a NEW 6.0 LS2 and build a LS2 402ci
or $600 on a NEW iron 6.0L bored .030 over, pushing displacement out to 408ci.
TSP is offering these starting around $3600.00.
although i didnt go with them, i picked up a LS block for $800.00 and got a local machine shop to cut me a deal that was competitive to TSP and SDPC, using a forged eagle 4' crank, forged eagle H bean rods, diamond pistons w/valve relief, nitrous rings, ARP main bolts. everything balanced and blueprinted. my cylinders were bored .005 over, making displacement technically 403ci. plus they let me pay what i could to get started and pay the balance once it was done. reusing my LS6 heads with a port and polish job stock valve sizes 308-314cfm@.600 lift. .608/.612 248/254 112 cam, im expecting 500-525ish, 470-480tq to the wheels on 11:1 compression. it should be done around 5/20/06.
now since ill have a LS6 block left over, probably going to take it to a 395ci and have it put in my girls '02 SS so she can kick some *** too.
Old 04-20-2006, 11:29 PM
Houston999's Avatar
more graphs please.
Old 04-21-2006, 08:40 AM
n20stroker's Avatar
my 402 makes 515 rwhp and 496 rwtq
