Anyone use a Mustang Dynamometer?
My car only had 242 RWHP and I had a free mod and a K&N filter. I forget the RWTQ, I am at work right now.
We also got 330RWHP from a Z06 and 188 RWHP from an Infiniti G35 with intake and exhaust.
Steve
Administrator
There's no direct correlation between a MD and a dynojet so you really
can't say there is a particular percentage difference. MD's do yield lower
numbers though.
In response to the original question, those numbers seem very low. I'd try another
dyno if you're looking for numbers. Keep in mind that they are tuning tools first
and foremost.
numbers though.
and foremost.
http://www.katechengines.com/street_...4074%20Cam.pdf
I experinced both dyno's. As you can see in the Sig with the 8psi run on a Dyno jet it made 548rwhp and 11psi on a Mustang Dyno it made 554rwhp even though its the same setup with just more boost. So assuming each psi would yield 20rwhp... that is at least 60rwhp lower reading on the Mustang Dyno at that power level. That would be around 7-9% lower on the two dynos i used.
