Curious Dyno Results w/ New Cam - need suggestions!
Reposted from the Internal Engine board, for different opinions possibly. Thanks!
Hey guys, I just finished my cam install this Thursday. Got a few hot/cold cycles in on the springs before I beat on it at all past 3K. Anyway, went to Dyno tune today, and the below graph is what I got. Im happy because the little cam I got had great results with no tuning at all. But, the bad side is obvious - past 6100, it dropped in power suddenly. No noises, no knock sensor, nothing at all. Just the power drop. Any suggestions at all? Parts are as follows:
Stock LS1 intake with !EGR.
Crane Cams Z-Cam, 224/224, .551/.551, 112 LSA
Crane Cams Dual Valve Springs
Crane Cams Gold Extruded Rocker Arms (1.7 ratio)
Crane Cams 7.250 Chromemoly Rods (came with the rocker arms)
BTW, sorry - no wideband graph. But, according to the dyno operator, the numbers were fine.
Originally Posted by lilbuddy1587
Rocker arms, happens all the time. Springs just cant take the added weight from what I understand.
Same thing happend to me and it was my rockers over powering my springs never changed the springs but went back to the stock rockers and it was fine pulled all the way to 6500 with a hot cam.
Originally Posted by vettenuts
Nope, not the rocker arms, the springs are likely the cause. Two ways to proceed, you can try shimming the springs or you can switch to the new 833 Crane springs.
Who did you get the setup from?
Shoot me a PM, I got your other one.
Rocker Arms, and damn, get a LS6 intake, you're killing yourself past 5K rpms for probably 25-30 horse with that LS1 intake lol. Not mention that is where your trq starts to fall too. Nice curve, but with the LS6 intake, you'll get a much nicer one =D.
But like everyone said, its the rocker arms, swap with the stockers and see what happens.
Adrian
Adrian
Adrian
Adrian
