Estimate my hp 402 ci AFR 225's
I am currently into my rebuild. Parts are as follows. SLP 402 High compression block, AFR 225cc heads, comp 238/240 .605/.608 cam, Fast 90/90, 36 lb injectors (may need bigger ?) , M6, 10 bolt with stock gearing. 2000 TransAm.
Mac mid length headers, y-pipe with cats, slowmaster exhaust. I am aware that the mac mid lengths and the slowmaster isn't the ideal setup for this combo lol.But it always gives me an excuse to spend more money later. I am probably going to put in a fidanza lightweight flywheel when putting everything back in. Also fuel pump in tank is upgraded and should be sufficient. Tune may be done by myself with ls1 edit. I have a WB o2 kit.
I'm thinking about 500 rwhp ? ANy ideas if thats close ? or what this comb. is capable of with a better LT exhause and higher flowing muffler ? If I decide to get it tuned by a pro any suggestions of a good tuner in or near CT ?
Thanks
Ron H.
Thanks
Ron H.
Yeah I know what you mean. I see a lot of people saying on this board that they have low numbers, when I look at there setup and it seems normal too me. I'm sure it must be depressing, I hope I don't wind up feeling the same way
Anyone else have any idea's ?
Ron H.
Ron H.
Originally Posted by Ksett
I would do the headers and exhaust before you dyno. You have all these great parts for your setup except the proper simple boltons.
Thanks
Ron H.
