dynoed at 723 rwhp
btw - I had it video'd (or so I thought)...by using a tripod and my cam (I used my remote control for my cam) but when I hit the record it must not of worked. So I have no proof that this is real. Have a nice day.
its true though. It was on the same dyno that tCTech was on.
see here
https://ls1tech.com/forums/street-racing-kill-stories/500473-memory-stories-but-good-none-less-05-tc-walked-01-mustang.html
see here
Originally Posted by Caveman
How much boost does it make with the cutouts open?
lol i always heard that turbo plus 300 shot worked extremely well together...probobly factory longblock and fuel system too...unleaded 87 octane.
how much boost w/ the cutouts open....hmm lemme look at my data book here that tracked my boost on the dyno - it made 19 psi w/ the exhaust open. 11 w/ it running through the mufflers. (w/ mufflers it put the power at 483 at the wheels.)
Up here I used 114 race fuel. w/ a edelbrock mechanical pump. <---
Originally Posted by HolyShiznit
^^^ You are a tard cart.
w/ nawz it puts down over 620 (on pump gas)
and it weighs 23 lbs. Only problem I've had w/ it is the traction issue (no weight, and the back wheels are about 6" in diameter, and about 1.5" wide.
Originally Posted by MYBLKWS6
I built a custom 4cyl shopping cart put down 102 hp at the wheels!!!! (but that was N/A)
I have a full bolt on 2007 cart with a full plastic cage from walmart I am also running a forge 9.9ltr ls1 with tripple ATI's 3 8in pullies my heads flow 1000 cfm at .100 lift my cam is a custom ground from old fence wire specs are 300/900 700/1000 on a 0.0lsa Im running 500psi with 3 in nittos
on a playskool dyno it put down 150 hp 7000tq at 3rpm
