Just Dyno'ed Should i be disappointed???
Old 05-23-2006, 07:16 PM
bigleman's Avatar
Default Just Dyno'ed Should i be disappointed???
Stock 99 C5 A4
50,804 miles
89*
24% Humidity
SAE: 0.98
It looked like it was doing damn good until the tech said it hit some sort of "spark detonation" (?) He said he stopped the run early, as soon as the drop happened. He doesnt know why the computer kept going but thats why the A/F is crazy at 5100-5400. The guys at the shop said it could be the computer advancing the timing too far or a bad batch of gas.
I was kinda disappointed with 288/292 until i realized it wasn't even testing at the peak rpm range.
Can anyone tell me what is going on here?
What is the problem?
What should I expect when i fix the problem?
Is this as good of a base as everone is saying?
Maybe i was just mad that i didnt see a 3 at the begining...
Old 05-23-2006, 07:17 PM
jessedale98's Avatar
not bad, sounds like a stock ls1 a4.
Old 05-23-2006, 11:13 PM
s346k's Avatar
+1
don't sweat it, sounds on par for a stock pre-01 ls1 a4.
i use 1/4 mile timeslips as my dyno. it is foolproof and leaves no questions. so get to the track!
Old 05-23-2006, 11:41 PM
bigleman's Avatar
any clue on whats going on at 5300 rpm?
Old 05-24-2006, 02:00 AM
prostock_bigblock's Avatar
what octane r u runnin ?
Old 05-24-2006, 12:07 PM
bigleman's Avatar
unless the station is screwing me, its only had 93 in it sense the day i bought it
Old 05-24-2006, 12:21 PM
chris93266's Avatar
you may have carbon build-up causing detonation. when your knock sensors detected the ping, they should have retarded timing, and i bet they would have if you had finished the pull. you should run some sea foam or take your car to a shop and get a carbon treatment done. after that, re-dyno and see how it does.
Old 05-24-2006, 01:19 PM
SideStep's Avatar
That is KR pulling timing. You can see the differnce in the line-angle climb rate before and after the knock...
MANY A4 C5 owners pull 280-290 (sae) factory. I am a little surprised you got KR at an AFR of 12...
BTW those wheels look bad-azz on a C5... where did you get them???
Old 05-24-2006, 01:23 PM
STRIPSTAR's Avatar
You could also see if your sucking major oil thru the pcv.
Old 05-24-2006, 04:23 PM
tx77015ls1's Avatar
my dyno/1/4 mile states in sig
Old 05-24-2006, 04:24 PM
tx77015ls1's Avatar
Oh BTW, 314 HP on 87 octane dynojet
Old 05-24-2006, 05:45 PM
bigleman's Avatar
I'll give the sea foam thing a shot and see if i can tell a difference. I'll re-dyno in about 2-3 weeks when i get the intake and exhaust done.
The wheels were on the car when i bought it. I dont know if the old guy who had it in FL before me put them on or if the dealership did. A lot of people are saying the C6s look good on my car. Too bad i cant say the same for the red camaro i saw with them 3 days ago...
Old 05-24-2006, 05:47 PM
bigleman's Avatar
umm ok.... congradulations?
good luck running 87 dynosaur **** in your car
Old 05-24-2006, 05:58 PM
WS6FirebirdTA00's Avatar
If you are running too rich, that can also cause knock.
Old 05-25-2006, 10:22 AM
allngn_c5's Avatar
Check your a/f ratio. the graph looks like you are 12 to 1. You could definately lean out to 12.8 or 12.9 to 1 while strapped on the dyno. You will lean a little bit more when you have fresh air moving while driving on the street.
Old 05-25-2006, 10:34 AM
98Z28MASS's Avatar
those numbers are pretty good IMO, especially with the new 10% ethanol gas in a stock ls1 a4 vette. I dunno but it kinda looks like valve float around 5300 rpms? Not certain but that could be it.
Old 05-25-2006, 11:24 AM
SideStep's Avatar
Why are you posting in this thread???
Old 05-25-2006, 04:41 PM
hahaha exactly what I was thinking...
Old 05-25-2006, 06:49 PM
bigleman's Avatar
How would i test for valve float?
EDIT:
Would valve float happen at the EXACT same spot each time?
Old 05-25-2006, 08:18 PM
98Z28MASS's Avatar
EDIT:
Im not exactly sure, ill post up my graph, it sorta got cut off when I was uploading it but my dsl is down so im on dial-up right now and it would take forever for me to load again. Here it is:
as you can sorta see I get that little dip around 5700 rpms. I dunno if its the same deal with your setup but after getting my cam installed and tuned it went away. The valve float came on my stock setup.
