Dyno'd on a Mustang... what'll I get on a Dynojet?
11Second Club
Hey all,
Here are my mods (cut and paste from sig, so lots of non-power-related stuff) and my dyno sheet. She put down 400/364 on a Mustang dyno. What should I expect on a Dynojet?
Mods:
SLP lid, K&N, SLP underdrive pulley, TR 230/236, Crane Cams springs, TR chrome-moly pushrods, QTP 1-3/4" LTs, QTP catted Y, Hooker catback, custom cutouts, tune by HPE, Strange Dana S60 w/ 4.10s, poly tranny mount, Pro 5.0, Textralia, G2 LCAs (rod/poly), Spohn adj. T/A (tranny mounted), Bilstein HDs, Brembos, Hawk HPS pads, 275 Nitto 555Rs, !AIR, !CAGS, and !molding.
Mods:
LS1 Tech Administrator
Hard to say as Mustang dynos vary a great deal. I've seen HPE's Mustang dynos be a lot closer to Dynojet numbers than most. For tuning, Mustang dynos are the best. For bragging rights, it's hard to get a big number out of them.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
man what was being used for rpm pick up and I wouldn't even put that graph up with it looking that way.. and I take it that wide band wasn't even hooked up??? looks like it was only pulled once maybe twice?? why is that?? don't seem like you went to learn much from your visit to the dyno with a crappy graph and no a/f
11Second Club
2) I assumed that a wide band was used. HPE is definitely a reputable shop, so I would freakin' hope so. He did say it was running lean up top, so he had to find that out somehow.
3) It was pulled four times. The sheet only shows the last one.
well he either done a roll speed calibration to pick up rpm if your a manual car or he used the inductive on the coil wires going into the coil itself not the plug wire.. if a plug wire was used I think this may have cause the sketchiness in the graph but hard to say as that one of the worst looking graphs I have seen.. and I am in no way ******* HPE. and the a/f I only said it didn't looked hooked up as the avg.. on your a/f was in the 7.xx range.. I know if we leave ours turned off the display will say like 7 to 8 a/f with nothing hooked up to it or powered up.. only reason I said a/f didn't look hooked up.. maybe dynocar or someone will back me or correct me if I am wrong here.
BTW for the mods you have your power is good.. just curious was this dyno run ran through virtual simulation on their dyno? if so do you know the numbers used on the cars weight and hp@50.. and you most likely will not know the answers to these questions but thought I would ask any..400 with just a cam on a MD is some damn fine numbers.. if the numbers are correct.. again maybe someone will correct me or are thinking the same as me.. we will see if anyone replies.
We use "smart tach" all the time, rarely a problem, if we do have a problem we use the smart tach's optical pickup, most accurate. We never use roll speed because it is impossible to get an exact MPH/RPM ratio due to many factors, such as tire growth as the MPH increases. Auto trans cars, especially higher stall speeds really throw the ratio off. Keep in mind, the dyno's calculations depend on accurate RPM readings.
I use the Smart Tach also without any problems. Although I do use the Optical pickup on about everything.
a few years ago on an old set up of mine i was on a dyno jet and got 391hp then went to a mustang dyno a week later and got 370hp. nothing at all changed on the car between the two dyno sessions. to say the least,i was ready to cry after seeing the mustang dyno #'s. today i dyno 463hp & 413.8tq on the same mustang dyno that almost made me cry.
Theres no set factor but 8-12 percent seems to be about the norm. You can "unload" the Mustang Dyno to get better numbers if thats what you really wanted to do. A Mustang Dyno is a better tuning tool and gives better actual real world hp and tq rating's as compared to a dyno jet which just spins freely.
Unloading a Mustang, or any dyno will decrease the HP/TQ readings, which most would not consider "better numbers", I don't think.
eddy current is not a dyno jet trade nor did they opt to use it till many years later after everyone wised up and found out what UH LOAD MATTERS! lol.. and what do you think a mustang dyno uses for load??? it has a eddy current load absoroption cell. two in some cases.
