TEA 215cc Trick Flow Dyno numbers and graph
Got my car back today from Norris. Tony Mamo said the numbers were average at best, but I am extremely happy. Conservative (safe) tune and a cam with under .600 lift. The car made 461rwhp and 406tq. There is more to be had in the combo, the was some minor port matching and cleaning up of the fast intake. I think in some nice weather and some minor work the 470's are steps away. I am going to install a cutout and see what gains I could get for a track setup. The car made peak power at 6700, limiter is at 6800, so the heads are doing there job. Now I have a base idea what I can look into, I am going to try to pick up the torque number, I have a feeling I will be getting a new cam shortly.
Blue...
I would have preferred you quote my entire post if you were going to single me out in your dyno thread. I do feel the numbers are average (not a bad thing) and are inline with your mods, but with all the recent hype these heads have seen lately aren't setting any records either. Thats alot of power and I'm sure with more tuning and optimizing you will find some more. Perseverence, time, and of course money usually pay off when it comes to these types of things.
For those who care, my entire commentary can be found on page two of this thread. Its a long post and I dont want to clutter up and hijack this dyno thread by copying it here.
https://ls1tech.com/forums/showthrea...=552661&page=1
Thanks,
Tony
Thanks,
Tony
LS1 Tech Administrator
I agree with you (Blue Meanie) on the cam change idea. With that duration on a 114LSA, you probably don't have the dynamic compression to make great power under the curve. While your top-end power is strong, I feel that with a better chosen cam, you should see your torque at 3000 rpm rise another 20-30 lb ft and your peak torque at least another 20. Good job and keep us posted on upcoming mods!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
First Congrats buddy those numbers are simply awesome & i'm sure those 215cc heads work damn good with your whole combo
Btw how much the heads were milled ?
peace
peace
Originally Posted by Tony Mamo @ AFR
Blue...
Thanks,
Tony
Thanks,
Tony
My power curve is definately a byproduct of the cam. When I got the final specs, it had low lift and high duration, but for me it was good. Right now I have the stock rear and gears, stock clutch, and cheap tires. The high curve is soft on those parts, exactly what I wanted. In the next few months I will have the 9 inch and 4.11's, stage 3 clutch and some stickies. Then I will go with the new cam and tighten up the setup, something with more smack down low. I didn't right away because I might be waiting on the other parts, since I have the opportunity to get a low milage LS1 for my z28. Whcih will be getting built with...ahem...AFR's . If I spend that money, I'll be waiting longer for the rear and gears. There is definately more to be had.
peace
peace
That is the highest hp/tq I have seen out of head and cam package (stock bottom end) strapped to NLPs dyno.
I hope my 224/228, AFR 205 combo can come CLOSE to that on the NLP dyno.
Great numbers!
Great numbers!
Damn good power in the Florida HEAT! Guys that don't live here don't understand how bad it hurts a car. I know......SAE correction factor, but I own a shop with a brand new Dynojet 224xLC and the correction factor only accounts for so much. See it all the time. Did it today, car that did 440 on a cool low humidity night did 431 today with the same parts SAE corrected. I bet you see some power in the cooler air! Nice setup.
BTW.....I have a 02 SS also and the wife drives a New TL!
Thanks for the kind words everyone! Car needs to be sorted a little, 4.11's and a 9inch, cage, clutch, shocks, tires.... Still have a long way to go. Its gonna be fun. I'm ordering these sparco seats tomorrow with matching rear seats, and a wolf cage.
BTW, I have some AFR heads you can borrow if you want to see the power difference.
Blue...
Thanks,
Tony
Thanks,
Tony
https://ls1tech.com/forums/generation-iii-internal-engine/391049-afr-224-228-cam-installed.html
Originally Posted by Brian Tooley
The great part about the cam is it's proven and dead reliable, it is VERY easy on springs. You can up the cam ramp speed and lift, but consider your springs when you do. You indicated your shortblock might be tired? With all things considered including the heat right now, I'd say you have a killer combo.
BTW Brian, I wonder what you could do with some heads tailored for a turbo....
great numbers. i have the exact same cam on a 112 and put down 443/403 in my Z06 with a stock manifold and 3:90 gears. this was with TEA ls6 heads. i have definatley made up my mind on the heads for my new project.
Guys, you can make LOTs more area under the curve with the same heads/intake without having to resort to a cam that is hard on parts. It's all about correct valve events. Your current cam has too late of an intake valve closing point and too low of dynamic compression. You could still run the soft XE lobes and pick up 20-30lb ft of mid-range torque with a better chosen cam. As it stands right now, your setup is very biased toward the top-end. The great news is, you can keep your strong top-end while picking up big numbers in the 3000-5000 range. If interested, send me a PM.
__________________
