Cam Only Dyno Numbers!!!......236/236
Old 08-08-2006, 11:09 PM
Demonicbird00's Avatar
Default Cam Only Dyno Numbers!!!......236/236
well roshan(chummmma) got me tuned in and i pulled a
418 RWHP and 380 RWTQ
heres the package i put in.
Comp Cam 236/236 .602/.602 114+2
ls2 timing chain
ls7 lifters
ls6 oil pump
comp dual springs
titanium retainers
SVO 30# injectors
now to hit the track in fall.
Big THANKS to Roshan and Joe, w/out them i counldnt have done it!!!
-brandon
Old 08-08-2006, 11:14 PM
ws6sojuiced01's Avatar
some good numbers there
Old 08-08-2006, 11:19 PM
chummmma's Avatar
way to go ... you didnt even post the graph... the torque carries well over 350 from roughly 3200 (when we started sampling) and holds past 6k.... the car is just an animal.car is asking for a fast 90/90 combo...
still needs a lil fine tuning... for some reason it kept gaining power increasing timing.... and had 0 knock so i gotta see when it stops making more power.. that run was with 30 degrees!
this same cam with a set of revalved ls1 heads on my car put down 411/389 through built a4 with a 4000 stall and a 12 bolt... with ls6 intake no ud pulley.
Old 08-08-2006, 11:25 PM
ill get the graph up tomorrow im posting the numbers on the all the boards and headed to bed lol.
-brandon
Old 08-08-2006, 11:44 PM
Black FormulaLs1's Avatar
dang good numbers!
Old 08-09-2006, 08:10 AM
Cgillies86's Avatar
Awesome numbers, I can't wait to see the graph. What is your full mod list? Did you flycut? I am getting my car tuned right now, I have a 236/236 .602/.602 LSA 113+0 with ported LS6 heads. I hope I can break the 440 RWHP mark. My compression will be between 11.31-11.78 depending on deck hieght, and my dynamic compression will be between 8.18-8.5X.
Old 08-09-2006, 08:45 AM
Toasty's Avatar
How does the car drive?
Old 08-09-2006, 11:16 AM
chummmma's Avatar
i have the same exact cam in my 00 Z28 in an auto... drives 1000x better then my old g5x2... even though i miss the g5x2's radical idle the g5x2 a/c would occasionally make it hunt with the 236/236 i can hit the aa/c and go into reverse quick and doesnt drop below 775 rpm (my idle is 825).
Old 08-09-2006, 12:19 PM
GR33N GoblinM6's Avatar
thought you said CAM ONLY ... not Cam + Injectors + Springs + Titanium retainers + oil pump + LS7(1.85) lifters, + tuning for 30#injectors..
Old 08-09-2006, 02:41 PM
you cant do cam only and not do the valvetrain.
car drives just asa good, love the nice idle now at stops.
cgillies86...you wont be disappointed in the cam choice. you should def see 440.
-brandon
Old 08-09-2006, 02:44 PM
slpss9723's Avatar
well you have to do supporting mods for a cam that size, ie. springs, retainers, etc. I put down 411 hp 385 tq with cam only (as in no heads, lifters, pistons, crank etc.)
Old 08-09-2006, 03:11 PM
Dave@LivernoisDSS's Avatar
Im really interested to see how your car runs afterwards
Old 08-09-2006, 04:52 PM
i can understand about the springs and retainers...
but LS7 lifters, 30# injectors.. tuning... no longer cam only
anyways.. nice gain.. let us know how streetable it is..
Old 08-09-2006, 04:58 PM
Azrael's Avatar
Tuning and injectors are just to get the Cam to run to its potential. Tuning tools per se. I can't think of too many people that would run any cam on stock tuning for very long without wanting to optimize their setup! Why spend the money for the requisite valvetrain upgrade, and cam itself without going the extra step and tuning it?
Old 08-09-2006, 05:05 PM
BriancWS6's Avatar
You CAN'T install a cam without upgrading your valvetrain. "Cam only" means just a cam, not heads/cam. It doesn't mean that's the only thing done
Old 08-09-2006, 05:20 PM
99_Z_155's Avatar
those are some pretty sweet numbers. i have a 233/239 .600 .605 and i got 375 or so hp. i havent been tuned yet though, and have yet to get an LS6 intake.
Old 08-09-2006, 09:39 PM
Cgillies86's Avatar
Me to I can't wait. Turns out my compression will be a bit lower. There was a problem with the smaller gasket so I now have the thicker stock gm gasket. Also, my pistons stick out of the block less than I thought. That will drop the compression down to 10.8:1 according to Dan. My dynamic compression is going to be a bit lower than I would like to see 7.83:1, so I will loose a fair amount of bottom end power. I still think 440RWHP will be within reach.
Old 08-09-2006, 11:29 PM
well in another thread i posted that i had to replace the lifters, due to one being gouged out and it scared the stock cam. the stock 26lb injectors wont hold the fuel supply for this cam either, they would be maxed out at around 4500.
its very nice and streetsable.
w/ even split cams the tuning is 10x easier and faster to get dialed in. she idles at around 900. and i love the good/bad looks i get sitting at a light lol.
-brandon
Old 08-09-2006, 11:52 PM
DONAIMIAN's Avatar
1.85 lifters
Im sure you meant 1.85 rockers, and hes still using the stock rockers. Theres not really any performance gain with going to LS7 lifters.
Old 08-10-2006, 12:38 AM
pdd
pdd's Avatar
stout numbers for cam only
