ls1 hotcam car on the dyno
Old 12-07-2006, 01:23 PM
Function>Form's Avatar
Default ls1 hotcam car on the dyno
what can i expect out of a car that dynoe'd 350/350 with full bolt ons TUNED
and im adding ls1 hotcam, ls6 springs, ls2 chain, and UD pulley? and another tune
Old 12-07-2006, 05:57 PM
Red99TA's Avatar
355/355, j/k I would say maybe 375/370
Old 12-07-2006, 06:48 PM
that sucks because everyone says the UD pulley gains 8-10 alone so that leaves the cam gaining only 10-15 hp....o man :-(
Old 12-07-2006, 08:21 PM
Havok2's Avatar
its a small cam
Old 12-07-2006, 10:20 PM
silverLS199's Avatar
my buddys car wit mac mids ory and lm1 and lid wit sum kinda aftermarket clutch put down 321 on sum dyno but i think the dyno was off car was a 02 Z it had a bad valve seal but still it had to be off by a good bit..right???
Old 12-07-2006, 10:46 PM
we_todd_did's Avatar
There was a guy at the dyno when mine was tuned, his had a pulley lts and cat back and hot cam, it dynoed 380 and I cant remember the torque
Old 12-07-2006, 11:56 PM
Hennytime's Avatar
ive seen as low as 350/350 and as high as 390/375 on the hotcam, i think im planning on getting one myself
Old 12-12-2006, 12:52 PM
pianoprodigy's Avatar
So many better cams. Even the baby 224/228 XE-R grind will be worlds better. I had that in my Z06 that my dad now owns and drives. I rode in the car today, and it purs like a kitten.
Old 12-12-2006, 03:09 PM
blkbird's Avatar
I gained 36rwhp with the hotcam.
Old 12-13-2006, 10:08 PM
mullenh's Avatar
yes but if you have an a4 and go larger you have to change the stall on the converter, doesnt the hot cam get by without that?
Old 12-14-2006, 12:43 AM
Asmodeus's Avatar
hot cam is a comparatively small upgrade vs what's available out there. 15ish to maybe 20rwhp is probably about right for it.
Old 12-14-2006, 12:47 AM
'Trust''s Avatar
I wouldn't hope for too much more than 360-375 with an A4. If it means anything my A4 stock stall (I know, retarded with a cam but I got the cam cheap!) with a TR 224, headers and tuned did a lil better than your bolt-on car. It wasn't that my car was weak, LS1 intake sucked, 853's suck. Now its good . Anyway like I said, I wouldn't expect more than 360-375 with an A4 and bolt ons without heads, and 375 is pushing it.
What were your final numbers/mods?
If your modding an A4 a stall should almost always go before a cam unless there is some strange hidden reason not to. A cam is almost worthless without a stall anyway in our A4's.
Old 12-14-2006, 10:12 AM
blkbird's Avatar
Before i put the heads on i was sitting at 375rwhp/362rwtq. That was with lid, LT's, ORY, crapmaster and tune. I have to go back and get it retuned since I added the LS6 heads, hooker muffler, and ported TB.
Old 12-14-2006, 03:45 PM
2000TransAmWS6's Avatar
i gained 32 rwhp and 32 rwtq to make my totals 375/378 with LTs, ORY, TSP rumbler, LS6 intake manifold, lid, descreened MAF, and tuned (unported TB, stock Pulley).
these guys saying 15rwhp gains either don't know what they're talking about, or are refering to cars that have them with stock manifolds (or are untuned).
Old 12-14-2006, 08:12 PM
Asmodeus's Avatar
all he's adding is an U/D pulley and a hotcam. He already had the dyno and tune with all the boltons.
Old 12-14-2006, 11:05 PM
Hennytime's Avatar
before you write off the hot cam, you also have to remember it has very little over lap, despite the 112lsa. i think its a .5* overlap, which is ideal for a supercharger, might not be the best butitll sound mean as ****
Old 12-15-2006, 09:42 AM
GrimReaper's Avatar
I just did a cam swap in a 01 WS6...buddies car, it has the LPE ls6 heads, ls6 intake,LT header. Went from the hot cam 386hp 381tq, to the 228R and actually lost 20ftlbs. Same dyno both times. Did gain about 6hp though.......time to go back to the hot cam. I just dont understand why it works that much better. I thought i would gain by swapping cams.
Old 12-20-2006, 09:53 AM
sorry man, i might not have explained myself right... i picked up 32/32 with just putting the hotcam in, my previous dyno i already had the other stuff i listed
Quick Reply: ls1 hotcam car on the dyno
