Headed to the Dyno- Place your bets...
Old 04-23-2008, 09:55 PM
fstphx's Avatar
Default Headed to the Dyno- Place your bets...
Lets hear your predictions (i know you guys hate these)
So we are planning a weekend thrash- (Hoping this weekend, if parts are all in, if not it will be next)
Starting with a 2001 WS6, Bone stock
R.G.R st2 heads.
Cam 238/242 605/610 113 lsa
Pacesetter LT Headers
TSP ORY
Magnaflow Catback
Rollmaster Double-Roller Adjustable Timing Set
TSP Ported LS6 Oil Pump
LS7 Lifters
ARP 12-Point Head Stud Kit
ARP Harmonic Balancer Bolt
GM LS1 Water Pump Gasket Set
GM LS1 Head Gasket Set, Multi-Layer Steel
GM LS1/LS2/LS6 Timing Cover Gasket
Non affecting items also putting on-
Boyd Coddington Smoothie IIs
Nitto 315/35R-17 555R Drag Radials
SJM Line Lock
I predict 451 rwhp
fstphx is offline
Old 04-23-2008, 09:59 PM
MattIROC's Avatar
You need to be more specific on a few things...
injectors?
gears?
tranny? if auto, what size stall?
what intake?
I'm sure I left a few out.
MattIROC is offline
Old 04-23-2008, 10:35 PM
fstphx's Avatar
Stock injectors, Stock gears, M6, Stock LS6 intake...
Its a stock car, the list is all we have planned (unless we missed something stupid)
fstphx is offline
Old 04-23-2008, 10:50 PM
MattIROC's Avatar
I'd say no more than 420 because of the injectors, gears, no aftermarket fuel pump.
MattIROC is offline
Old 04-23-2008, 11:00 PM
fstphx's Avatar
I was under the impression stock fuel pump would be good enough for 525 or so, Injectors 475ish... I can always add to the list
fstphx is offline
Old 04-23-2008, 11:10 PM
MattIROC's Avatar
You have the smaller injectors, probably will max out around 420 rwhp? Unsure what the stock fuel pump can handle. I would say no more than 450 rwhp, but I'm sure I'll get corrected.
MattIROC is offline
Old 04-23-2008, 11:28 PM
fstphx's Avatar
'01 has larger the bigger 28.6# injectors not saying they wont be maxed, this has gotten me reading- thanks-
fstphx is offline
Old 04-24-2008, 12:10 AM
Fabrizi's Avatar
Not familiar with those heads....but on a stock rear/tranny....450 isn't unreasonable. I'll throw 437rwhp out there.
Fabrizi is offline
Old 04-24-2008, 01:18 AM
LSX Mechanic
Damian's Avatar
The general consensus between the mods were that these types of threads added no useful content to the section.
Feel free to post up another thread after you dyno, with all the info you wish.
Damian is offline
