NEW 408 w/ L92/LS3 Heads & GMPP Single Plane Intake Dyno Numbers
Old 05-22-2008, 07:45 PM
WizeAss's Avatar
Thumbs up NEW 408 w/ L92/LS3 Heads & GMPP Single Plane Intake Dyno Numbers
Car dyno'd 456hp and 515tq yesterday at Real Performance Motorsports in Lewisville Tx.
Previous numbers where 429/438.
Major Changes:
Tuning
Neil Chance Converter (instead of Art Carr Converter)
Intake port smoothing
PCV System Installation
Drivetrain Pinion Angle Correction
Not bad for 42lbs worth of wheels and tires on the corners!
Old 05-22-2008, 09:53 PM
Richard@WCCH's Avatar
Nice work!
Considering the driveline losses that's some nice power your making.
As I recall you're running a relatively small cam hence the high torque peak. Must have a very big torque curve as a result.
When do you hit the track?
Richard
Old 05-22-2008, 10:00 PM
venom ws7's Avatar
More info please!! Compresstion?? cam??....
Old 05-22-2008, 11:37 PM
Dynojet Fan
VH5150's Avatar
its ok... not bad, i guess... need track times..
Old 05-23-2008, 04:13 AM
bad95killer's Avatar
Numbers look damn great just back it up with some ETs
peace
Old 05-23-2008, 05:46 AM
edcmat-l1's Avatar
Yeah, uh huh, not too bad for a 9 inch, th400, unlocked stall, etc, etc.
I think they're pretty good.
Can you post a graph? I would imagine the 515 is from the converter flash?
Old 05-23-2008, 08:21 AM
WizeAss's Avatar
11.25:1 compression
Greg Good Ported L92 Heads
HKE 408 w/ Diamond Flat Tops
Synergy Motorsports custom L92 cam (approx. 236's duration)
2 piece truck style Steel Drive Shaft
TH400 with 9 inch 3600 Neil Chance Converter
American Racing Torque Thrust 2's
M&H 325/17 drag radials
9 inch Moser with spool
GMPP Carb Style Intake w/ EFI
-stock maf tune
-stock pulley
-stock waterpump
Dont have the graph yet, would like to see if I can pick one up.
Old 05-23-2008, 09:18 AM
Randy_S's Avatar
Why did you go with a 2 piece driveshaft if I may ask?
Do you think that the pinion angl helped your numbers at all?
Old 05-23-2008, 09:45 AM
WizeAss's Avatar
Some mexican dude at a driveshaft shop did it. It was his idea.... It is kinda weird... I will see if I can get pics.
Dont know if pinion going from +9 to -1.5 makes a difference.
Old 05-23-2008, 01:34 PM
WizeAss's Avatar
Old 05-23-2008, 01:51 PM
WizeAss's Avatar
Nitrous?? naaaah... I don't see any nitrous... just a small fuel tank
freshly painted ***:
Strackcar stance:
Old 05-23-2008, 02:18 PM
AU N EGL's Avatar
Have a dyno graph that shows RPM on bottom line ( x axis) ?
Old 05-23-2008, 04:59 PM
WizeAss's Avatar
yeah.... away from scanner... that pull was from 3500 to 7k.... the cross is 5200rpm.
Old 05-23-2008, 05:00 PM
WizeAss's Avatar
just made 426 on nitrous tune and 563 on a 150shot......... not bad!
Old 05-23-2008, 05:20 PM
eric01ss's Avatar
u going to the track sunday mike?
Old 05-23-2008, 05:28 PM
LS1 Tech Administrator
Patrick G's Avatar
Stock MAF are you kidding me? Replace that with an 85mm MAF and see what happens to your KPa at WOT. Major choke point at your cubes and rpm level.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 05-23-2008, 06:33 PM
edcmat-l1's Avatar
I agree. I'd ditch the maf completely, and go SD with a wide open throttle body.
Looks like I was right about the torque. It usually happens that way with big unlocked stalls. The torque peak is at the hit, when the converter flashes.
Old 05-24-2008, 06:50 AM
AU N EGL's Avatar
Cross is always at 5200. Wondering of the torque curve from 3500 to 5200.
Would have like to have seen 2000 and up pull.
But Looking very very good
Old 05-24-2008, 11:45 AM
WizeAss's Avatar
Car ran a best on motor of 7.31 @ 94, but the shift light didnt come on so it was stuck in 1st a bit too long.
On the 150 shot (565rwhp) it ran a 6.6@102mph with a 1.46 60ft..... weight with driver was 3795lbs. Considering it has been 108mph with 635rwhp on a B.S. setup and a 1.48 60ft.... I am sure it will go bottom 6's on the 200 shot.
Old 05-24-2008, 12:01 PM
edcmat-l1's Avatar
You cant with that type of converter. Even if you start it at 2000, the graph will show up as starting where the converter flashes to.
I've started em at 2500, and had the graphs start at 5000 because of this. Never figured out why, its just the way it is.
Quick Reply: NEW 408 w/ L92/LS3 Heads & GMPP Single Plane Intake Dyno Numbers
