6.0L, L92's, MS4 at 108lsa GMPP and Dave's elbow
Old 05-28-2008, 07:44 PM
BES Stroked Nova's Avatar
Default 6.0L, L92's, MS4 at 108lsa GMPP and Dave's elbow
Well after I got my trans problem figured out, we made some pulls at the local dyno.
My setup is this
-06 LQ9 block from GMPP
-08 LY6 6.0L crank rods and pistons with ARP pro rod bolts
-stock unported L92's with manley valves, springs, retainers etc etc
-stock rocker arms
-Morel high rev LSx lifters
-heads were milled .075" along with the GMPP L92 carb/efi intake.
-MS4 cam set in at 108LSA
-double roller heat treated chain and ported LS6 pump
-Nitro Dave's elbow with 1" carb spacer to clear GMPP intake.
-Holley 90MM tb
-pistons had to be cut to clear the MS4 on the intake side, the exhaust already had the notches.
-BES Racing Engines did all of the machine and assembly work.
car is a m6 12 bolt with 4.10's and chrome z06's.
here is the dyno graph. we are also going to try a 4150 style tb on top on the GMPP intake.... sometime soon.
All in all for what it is, I am pretty damn happy. I had a run in with a ms3 cammed 99Z that made 390 and he sprayed a 175 shot on me and could only pull about a car on me from a 40 roll to 130....
Attached Thumbnails 6.0L, L92's, MS4 at 108lsa GMPP and Dave's elbow-dyno-runs.jpg
Old 05-28-2008, 08:38 PM
allngn_c5's Avatar
Not to bad man. All that power and 4.10's she must pull like a MULE on steroids.
Old 05-28-2008, 10:25 PM
articz28's Avatar
sweet.
Old 05-28-2008, 10:33 PM
O6DODGE's Avatar
any pics of the setup?
Old 05-29-2008, 06:11 AM
gtodoug's Avatar
peak power is nasty!
Old 05-29-2008, 09:20 AM
s346k's Avatar
what setup is this one laid over on the dyno? 450whp through a 6 spd 12 bolt seems awfully low for an L92 headed 6.0 motor with that much compression and a carbed intake. i think removing the elbow will bring up some hp, but not the 50whp i'd expect out of a combo like this.
interesting to see what the 108 lsa (how much advance/retard?) and carbed intake did, even on the 6 liter motor...pulls good from 6-7,300.
Old 05-29-2008, 09:55 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Not bad numbers at all, IMO! I'd figure (and these are very approximate figures) you have around a 60cc chambers, and I'd guess something like 3cc worth of valve reliefs. That would net you about 11.1-11.2:1 static compression. Let us know how she runs at the strip!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-29-2008, 06:59 PM
I am happy with it... the intake valve is very shrouded with a 4" bore...
anyways Its going to the track full street trim with ET streets tomorrow.
Saturday we are putting on a 1500 CFM 4150 throttle body and see if that elbow(which i think it is) is holding back power.
It made 480whp from 6500 to 7500 when the belt broke off on one of the pulls!
Old 05-29-2008, 07:39 PM
GreenBlood's Avatar
sweet numbers man, my car is begging for a cam...gotta have the funds though, haha...
Old 05-30-2008, 05:52 AM
bad95killer's Avatar
Great numbers man
I do agree
peace
Old 05-31-2008, 10:13 AM
oldschoolmuscle's Avatar
i thought the numbers seem a little on the low side...
Quick Reply: 6.0L, L92's, MS4 at 108lsa GMPP and Dave's elbow
